[mapguide-users] Mg build error on Ubuntu 6.10
Chris Gountanis cgountanis at mpower-tech.com
Fri Mar 2 11:53:49 EST 2007
You could try
./build_oem.sh > /dev/null
and see if you are getting any missing LIB errors. It is kind of hard to see
with all the compile information crap flying by. This will only give
warnings and errors as output. Maybe you need a lib for example I needed the
CURL and libXML2 lib files before PHP would compile.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of François Van
Der Biest
Sent: Friday, March 02, 2007 10:51 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mg build error on Ubuntu 6.10
Thank's for your help Chris, but that didn't help.
Same problem occurs :-(
F.
2007/3/2, Chris Gountanis <cgountanis at mpower-tech.com>:
> Could try this:
> ****** Fix DWF Build SH ******
> Edit build_setup.sh files with "libtoolize --copy --force" after
"autoreconf
> --force" (no quotes)
> nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_set
> up.sh
> nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfemap/build_set
> up.sh
> nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwftoolkit/build_
> setup.sh
> cd mapguide-1.1.0
> ./build_oem.sh
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
