[mapguide-users] RE: Request for help inserting new row into SDF
file.
GM_Mizar
giampiero.massa at torino.miz.it
Fri Mar 2 05:04:51 EST 2007
Hi Matt,
I've read your message. I have the same problem with an read-only FDO
connection but I don't understand how to use the mapagent to set this
property to false.
Can you please give me some instructions about this operation?
Thank you a lot in advance.
GP
Matthew D wrote:
> Thanks Dave,
> Jason finally got it working. You were correct, the sdf xml content was
> set to Readonly.
> Unfortunately there did not seem to be a way in Studio to set it to
> writable.
> The mapagent tool was used to both detect it as readonly and set it to
> false.
> Thanks,
> Matt
> Dave Wilson-3 wrote:
>> A geometry property is optional.
>> More importantly is the existing SDF ReadOnly? If you do a
>> DescribeSchema on it is it listed as ReadOnly?
>> Is it possible that you are inserting a duplicate key value? That will
>> fail silently (known bug).
>> Dave
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: Tuesday, February 27, 2007 5:32 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] Request for help inserting new row into
>> SDF file.
>> I don't think you can insert data without a geometry component in SDF
>> files.
>> - Jackie
>> Matthew D wrote:
>>> I am attempting to insert a feature/record into an SDF file. The
>>> record does not have any geometry.
>>> I have no problem returning data from this code $featureReader =
>>> $featureService->SelectFeatures($featureResId, $class, $queryOptions);
>>> The insert method doesn't seem to work AND does not give any error
>>> messages why not.
>>> $propertyValues = new MgPropertyCollection(); $propertyValues->Add(new
>>> MgInt64Property('mow_id', 3)); $propertyValues->Add(new
>>> MgInt64Property('seg_id', 2231)); $propertyValues->Add(new
>>> MgInt16Property('percent_required', 100)); $propertyValues->Add(new
>>> MgStringProperty('contractor', 'Mow Machine 65'));
>>> $propertyValues->Add(new MgStringProperty('mow_date', '20070202'));
>>> $propertyValues->Add(new MgStringProperty('comments', 'Some
>>> comments'));
>>> $commands = new MgFeatureCommandCollection(); $commands->Add(new
>>> MgInsertFeatures($class, $propertyValues));
>>> $featureService->UpdateFeatures($featureResId, $commands, false);
>>> Could someone tell me if there is something I am missing, or if there
>>> is some way to find out why this is not working?
>>> Thanks,
>>> Matt
>> View this message in context:
>> http://www.nabble.com/Request-for-help-inserting-new-row-into-SDF-file.-
>> tf3303740s16610.html#a9195532
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Request-for-help-inserting-new-row-into-SDF-file.-tf3303740s16610.html#a9266951
