[mapguide-users] digitizing features
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Mar 6 10:01:28 EST 2007
christoph g napisał(a):
> Hi Jackie,
> thank you for your explanation, but there are some questions left:
> - I visited the website http://data.mapguide.com/mapguide/devguide/index.php
> and I think my project should work similar to this. The digitized features
> should be transfered to esri shapefile, if not possible, to mysql database -
> I hope this is possible.
yes it is...just see source code of
there are very good example...so if you get x,y of points, line...etc.
the simply use database whit GIS suport (PostGIS in PostgreSQL) put this
cords into database...it work.
> - where (in whitch file or segment fo studio) do I call the DigitizeXXX
> javascript method?
...you call DigitizeXXX javascript method from viewer in webbrowser.
so this is work for developer.
maciek
