[mapguide-users] RE: render service
Jason Birch
Jason.Birch at nanaimo.ca
Wed Mar 7 11:57:54 EST 2007
It may on the server, but I try to measure performance at the client
side, with a less-than-high-speed connection in mind. This is why I've
enabled dynamic gzip (with deflate as an alternate) compression on my
web sites for HTML, etc, even though it means that IIS, Apache, or PHP
pulls more CPU. Of course, I'd have to back off on this if I started
running out of hardware :)
I'm not sure if image compression gives the same cost/speed advantage
though. Especially if it's trying to apply a linear compression to
continuous data.
Jason
-----Original Message-----
Subject: RE: render service
PNG images are already compressed with deflate internally. You would not
gain anything by compressing them again. I actually wonder if reducing
the compression level when rendering pngs would make things go faster,
since deflate() is a major CPU hog.
