[mapguide-users] RE: King FDO layer theme problem
shreepad shreepadr at valuecad.com
Thu Mar 8 14:18:56 EST 2007
when you said manually where should i theme it. do you mean programatically
?? or at database leve
thanks
Shree
haris kurtagic wrote:
> I tested now and it looks to me that theme you can do with King.Oracle.
> Error which comes out is if you use Theme dialog in Studio, because
> provider is not suporting aggregate functions yet.
> If you manually add rules for theme it should work.
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad
> Sent: 8. marec 2007 9:17
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] King FDO layer theme problem
> Hi Harris
> the FDOs are really great!!
> thanks for getting this to community. I am using Oralce XE and Autodesk
> MGE.
> and FDO 3.1 i tried to theme the layer but still it does not do it . i
> have
> attahced the error file to this email.
> please let me know how can i theme the layer  (point, polygon, line)
> thanks
> Shree
> http://www.nabble.com/file/7028/111.bmp
> http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#
> a9370316
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#a9381014
