[mapguide-users] RE: RE: King FDO layer theme problem
shreepad
shreepadr at valuecad.com
Thu Mar 8 20:11:46 EST 2007
good i got that. but if i have large dataset where i will need to use the
studio to do the themeimg do you thing provider will have that in next
realease.
secondly
i have created the spatial query in oracle for selecting intersecting
parcel with zone polygon. but when i try to view that view using provider it
gives me error. do you have support for spatial quries in provider version
4.0
thanks
Shree
haris kurtagic wrote:
> I thought on a button 'Add a Rule' next to button 'Theme...'
> I am not that much in MG Studio but I suppose you will get the same
> result.
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad
> Sent: 8. marec 2007 20:19
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: King FDO layer theme problem
> when you said manually where should i theme it. do you mean
> programatically
> ?? or at database leve
> thanks
> Shree
>> I tested now and it looks to me that theme you can do with
> King.Oracle.
>> Error which comes out is if you use Theme dialog in Studio, because
>> provider is not suporting aggregate functions yet.
>> If you manually add rules for theme it should work.
>> Haris
>> Sent: 8. marec 2007 9:17
>> Subject: [mapguide-users] King FDO layer theme problem
>> Hi Harris
>> the FDOs are really great!!
>> thanks for getting this to community. I am using Oralce XE and
> Autodesk
>> MGE.
>> and FDO 3.1 i tried to theme the layer but still it does not do it . i
>> have
>> attahced the error file to this email.
>> please let me know how can i theme the layer (point, polygon, line)
>> thanks
>> Shree
>> http://www.nabble.com/file/7028/111.bmp
>> View this message in context:
> http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#
>> a9370316
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> a9381014
View this message in context: http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#a9386786
