[mapguide-users] Re:Asp.Net Example
porta giorgio hopera at yahoo.com
Fri Mar 9 06:03:04 EST 2007
Dear GM
Very kind if you can send to my email address your examples.
Thank you in advanced
Giorgio
----- Original Message ----
From: "mapguide-users-request at lists.osgeo.org" <mapguide-users-request at lists.osgeo.org>
To: mapguide-users at lists.osgeo.org
Sent: Friday, March 9, 2007 11:52:34 AM
Subject: mapguide-users Digest, Vol 3, Issue 48
Send mapguide-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/mapguide-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    mapguide-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of mapguide-users digest..."
Today's Topics:
   1. Re: lines over maps (GM_Mizar)
   2. RE: RE: RE: King FDO layer theme problem (Haris Kurtagic)
   3. King Oracle: geometry does not display (Per Soderstrom)
   4. Re: mapguide-users Digest, Vol 3, Issue 47 (porta giorgio)
Message: 1
Date: Fri, 9 Mar 2007 00:44:19 -0800 (PST)
Subject: Re: [mapguide-users] lines over maps
Message-ID: <9390462.post at talk.nabble.com>
Content-Type: text/plain; charset=us-ascii
OK.
Now I'm using SDF (I've changed the readOnly property) and all is working, I
can add features to the source and lines apperas on the map with the right
style.
Thanks to everybody for the help!
Bye
GM
View this message in context: http://www.nabble.com/lines-over-maps-tf3328503s16610.html#a9390462
Message: 2
Date: Fri, 9 Mar 2007 10:59:06 +0100
Subject: RE: [mapguide-users] RE: RE: King FDO layer theme problem
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
    <E4D44138BD8AF742AB4A08D3B717643A06E312 at vmdc2003.sl-king.com>
Content-Type: text/plain;    charset="US-ASCII"
Yes, I will add support for aggregate functions.
Not sure which version of provider you mean ( I believe I have never
released 0.4.0 but 0.4.3 0.4.4 )
Views are supported ( I suppose you added in sdo_metadata that view
also)
With latest version of provider you can define more in detail how FDO
class is generated from view using KingFdoClass
http://www.sl-king.com/fdooracle/KingFdoClass.htm
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad
Sent: 9. marec 2007 2:12
Subject: [mapguide-users] RE: RE: King FDO layer theme problem
good i got that. but if i have large dataset where i will need to use
the
studio to do the themeimg do you thing provider will have that in next
realease.
secondly
i have created the spatial query in oracle  for selecting intersecting
parcel with zone polygon. but when i try to view that view using
provider it
gives me error. do you have support for spatial quries in provider
version
4.0
thanks
Shree
haris kurtagic wrote:
> I thought on a button 'Add a Rule' next to button 'Theme...'
> I am not that much in MG Studio but I suppose you will get the same
> result.
> Haris
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: 8. marec 2007 20:19
> Subject: [mapguide-users] RE: King FDO layer theme problem
> when you said manually where should i theme it. do you mean
> programatically
> ?? or at database leve
> thanks
> Shree
>> I tested now and it looks to me that theme you can do with
> King.Oracle.
>> Error which comes out is if you use Theme dialog in Studio, because
>> provider is not suporting aggregate functions yet.
>> If you manually add rules for theme it should work.
>> Haris
>> Sent: 8. marec 2007 9:17
>> Subject: [mapguide-users] King FDO layer theme problem
>> Hi Harris
>> the FDOs are really great!!
>> thanks for getting this to community. I am using Oralce XE and
> Autodesk
>> MGE.
>> and FDO 3.1 i tried to theme the layer but still it does not do it .
i
>> have
>> attahced the error file to this email.
>> please let me know how can i theme the layer  (point, polygon, line)
>> thanks
>> Shree
>> http://www.nabble.com/file/7028/111.bmp
http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#
>> a9370316
> a9381014
a9386786
Message: 3
Date: Fri, 9 Mar 2007 00:38:40 -0800 (PST)
Subject: [mapguide-users] King Oracle: geometry does not display
Message-ID: <9390406.post at talk.nabble.com>
We have made a connection using King Provider for Oracle (version 0.6.2) in
MapGuide Studio. The Feature Class looks OK, we can create a layer and add
it to a map without any errors. But we cannot see any geometry, either in
preview or in the viewer. We have tried both linear and polygon data. I have
also looked at the data using Fdo2Fdo and the SDO Metadata DIM INFO looks
OK. The coordinate system is *XY-M* (Arbitrary X-Y Coordinates (Meters)).
Can that be a problem?
Regards,
Per Soderstrom
View this message in context: http://www.nabble.com/King-Oracle%3A-geometry-does-not-display-tf3374407s16610.html#a9390406
Message: 4
Date: Fri, 9 Mar 2007 02:52:29 -0800 (PST)
Subject: [mapguide-users] Re: mapguide-users Digest, Vol 3, Issue 47
Message-ID: <237063.37090.qm at web52703.mail.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1
Dear GM
Giorgio
Sent: Friday, March 9, 2007 9:32:27 AM
Subject: mapguide-users Digest, Vol 3, Issue 47
Today's Topics:
   1. Re: Java enhancements (Joel Carranza)
   2. RE: RE: King FDO layer theme problem (Haris Kurtagic)
   3. Re: Java enhancements (Robert Bray)
   4. Re: Java enhancements (Robert Bray)
   5. RE: RE: King FDO layer theme problem (shreepad)
   6. GetMapImage and GetMapTiled (Kencana)
   7. Re: Asp.Net Example (Colette)
   8. Re: Asp.Net Example (MaciekS)
Message: 1
Date: Thu, 08 Mar 2007 12:23:35 -0800
Subject: Re: [mapguide-users] Java enhancements
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Message-ID: <45F070C7.5040404 at gatekeeper.com>
Content-Type: text/plain; charset="iso-8859-1"
Jason,
Fantastic idea. I sure wish they had Google Summer of Code when I was a
student. Regarding my comment about "better-informed designed decisions"
: The info I put in my ticket is everything I see (for now), but I
haven't dealt with the whole API. I will update the ticket as I run
across anything else which seems weird.
Joel
Jason Birch wrote:
> Hi Joel,
> We're going to be putting SWIG enhancements for Java in as one of our Google Summer of Code project ideas.  If it gets accepted, your input will really be appreciated:
> http://trac.osgeo.org/mapguide/wiki/GoogleSoC2007 <http://trac.osgeo.org/mapguide/wiki/GoogleSoC2007>
> If there are any students lurking on this list with nothing to do this summer, I fully expect all of you to apply :)
> Thanks for letting me know about the broken links.  They should be working now.  Between development and launch we had a change in the canonical URL for that site, and they got missed.
> You said:  "A couple of better-informed design decisions need to be made on how the Java API should look, and these decisions should be done quickly, so that java developers can know what to expect."
> Is this apart from what you put into the ticket?  Please add any additional info to the ticket.
> If breaking backwards compatibility at this point is necessary to make a more sane Java environment, I personally wouldn't be entirely opposed to it, but I'd really want to be sure that it is necessary first.
> Thanks,
> Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070308/7419f4cd/attachment-0001.html
Message: 2
Date: Thu, 8 Mar 2007 22:03:53 +0100
Subject: RE: [mapguide-users] RE: King FDO layer theme problem
Message-ID:
    <E4D44138BD8AF742AB4A08D3B717643A06E309 at vmdc2003.sl-king.com>
Content-Type: text/plain;    charset="us-ascii"
result.
Haris
programatically
thanks
Shree
King.Oracle.
> Haris
> Hi Harris
Autodesk
> MGE.
> and FDO 3.1 i tried to theme the layer but still it does not do it . i
> have
> thanks
> Shree
> a9370316
a9381014
Message: 3
Date: Thu, 08 Mar 2007 14:13:49 -0700
Message-ID: <45F07C8D.80805 at robertbray.net>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
FYI - The links on the New Ticket page are now fixed.
Bob
Joel Carranza wrote:
> Jason,
> Joel
> Jason Birch wrote:
>> Hi Joel,
>> Thanks,
>> Jason
Message: 4
Date: Thu, 08 Mar 2007 14:22:56 -0700
Message-ID: <45F07EB0.4060805 at robertbray.net>
Joel,
The person taking this on would need to investigate this further, but I
think it would be possible to simply generate new "enhanced" and old
"crufty" Java wrappers. That might be the best solution to the
compatibility issue.
Bob
> Jason,
> Joel
> Jason Birch wrote:
>> Hi Joel,
>> Thanks,
>> Jason
Message: 5
Date: Thu, 8 Mar 2007 17:11:46 -0800 (PST)
Message-ID: <9386786.post at talk.nabble.com>
good i got that. but if i have large dataset where i will need to use the
realease.
secondly
parcel with zone polygon. but when i try to view that view using provider it
gives me error. do you have support for spatial quries in provider version
4.0
thanks
Shree
> result.
> Haris
> programatically
> thanks
> Shree
> King.Oracle.
>> Haris
>> Hi Harris
> Autodesk
>> MGE.
>> have
>> thanks
>> Shree
>> a9370316
> a9381014
View this message in context: http://www.nabble.com/King-FDO-layer-theme-problem-tf3367836s16610.html#a9386786
Message: 6
Date: Thu, 8 Mar 2007 21:58:42 -0800 (PST)
Subject: [mapguide-users] GetMapImage and GetMapTiled
Message-ID: <9388954.post at talk.nabble.com>
Hi All,
Just find out that, getmapimage is actually a little bit faster in
generating a initial map view than getmaptiled.
I am not sure whether I am right about this or not. but if it is true, can I
know why it is faster than maptiled?
Thanks
Regards,
Kencana
View this message in context: http://www.nabble.com/GetMapImage-and-GetMapTiled-tf3373916s16610.html#a9388954
Message: 7
Date: Thu, 8 Mar 2007 22:02:44 -0800 (PST)
Subject: Re: [mapguide-users] Asp.Net Example
Message-ID: <9388997.post at talk.nabble.com>
  i you oblige me  that could help a lot to me too
  can you send them to me ?
colette
GM_Mizar wrote:
> porta giorgio wrote:
>> Hi to all,
>> it's possible to find and where asp.net example of developer source code.
>> Thanks in advanced
>> GP
> I've translated some examples from PHP to ASP.NET, quite all examples
> listed in the MapGuide Open Source Developer's Guide. They are not
> organized or structured but if you think they can help you I'll be happy
> to send them to you by email.
> Ciao
> GM
View this message in context: http://www.nabble.com/Asp.Net-Example-tf3368615s16610.html#a9388997
Message: 8
Date: Fri, 9 Mar 2007 00:32:25 -0800 (PST)
Message-ID: <9390329.post at talk.nabble.com>
Dear GM
Would I ask you for this example also?
Regards, Maciek
>> Hi to all,
>> Thanks in advanced
>> GP
> Ciao
> GM
View this message in context: http://www.nabble.com/Asp.Net-Example-tf3368615s16610.html#a9390329
End of mapguide-users Digest, Vol 3, Issue 47
____________________________________________________________________________________
8:00? 8:25? 8:40? Find a flick in no time
with the Yahoo! Search movie showtime shortcut.
http://tools.search.yahoo.com/shortcuts/#news
End of mapguide-users Digest, Vol 3, Issue 48
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
