[mapguide-users] Properties pane-layers pane height
Tim Eisler
Tim.Eisler at ci.dublin.ca.us
Wed Mar 14 11:54:37 EDT 2007
You can change the legend height in the viewerfiles/ajaxmappane.templ file.
There is a variable which controls the legend height aptly named
"legendHeight".
I changed the default value of 250 to 550 on my map to lengthen the legend
and reduce the size of the property pane, which resizes to the legend
height. I found that if you use Studio to turn off the property pane by
default, you get a fun y-shift in the map where the cursor does not match
the map coordinates.
var legendHeight = 550, initLegendHeight;
//var legendHeight = 250, initLegendHeight; changed by TEE
If you want to see an example of this in action you access the City of
Dublin's website at:
http://209.172.109.140/gis
Good luck!
Tim Eisler
GIS Coordinator
City of Dublin
tim.eisler at ci.dublin.ca.us
pmarseil wrote:
> Hi all,
> Can someone could tell me please where i can change the height of the
> properties and layers pane. It's possibly in the viewers files, but i
> can't find it.
> Big thanks
View this message in context: http://www.nabble.com/Properties-pane-layers-pane-height-tf3396190s16610.html#a9477358
