[mapguide-users] Handle the Double-Click event on the Map
Scott McFarlane
scott at geotropix.com
Wed Mar 14 14:14:14 EDT 2007
Hi Karam,
Are you using the AJAX viewer? When using the AJAX viewer, just about
anything is possible. The following JavaScript code, when placed in the task
pane page for example, will initialize an event handler for the double-click
event on the map.
var main = parent.parent;
var map = main.GetMapFrame();
map.ondblclick = function(e)
// Only respond in selection mode.
if(map.tool != 0)
return;
var x = e.clientX - map.mapPosX;
var y = e.clientY;
var pt = map.ScreenToMapUnits(x, y);
alert(pt.X + ',' + pt.Y);
This example simply displays an alert box with the double-clicked location
in map units. Hopefully this will get you started.
- Scott
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of m.karam
Sent: Wednesday, March 14, 2007 11:47 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Handle the Double-Click event on the Map
How can I handle double-click event on the map?
Regards
Karam
View this message in context:
http://www.nabble.com/Handle-the-Double-Click-event-on-the-Map-tf3402946s166
10.html#a9477169
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
