[mapguide-users] RE: Exception in Search Result
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu Mar 15 00:42:42 EDT 2007
Hi Andy Morsell,
I received your mail. when i try to search then i get value from layer but
it not Display and generate Exception Error but when i try to enter wrong
value then it succsfully return 0 result, i want to tell you that i was used
sheboygan.mgp and phpviewersample example. and in my current projects i want
to follow same way so for that resion some changing in findparcel.php and
some other file i want try to search booth but i am getting one Exception. I
am again repeating generated Exception :->
Find Results BOOTH_NO = '35'The specified object was not
found.The specified object was not found. Exception occurred in method
GetItem at line 115 in file
c:\build_tux_area\mgdev\common\service\data\NamedCollection.cpp
Please help me.
Best Regards,
Dhirendra kumar
Andy Morsell wrote:
> Are you trying to search on a field from an extended resource?  If so, the
> Search functionality currently does not support this.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Wednesday, March 14, 2007 4:35 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Exception in Search Result
> Hi All,
> I am making one Election web GIS Application using MGOS and through this
> application i want to search some particular booth by using their
> attribute
> BOOTH_NO. But when i go to search Booth number then i got this type of
> Exception -> Find Results BOOTH_NO = '35'The specified object was not
> I am sure that query return some value for that Layer but why i get this
> Exception. Please help me.
> Thankyou in advance
> Dhirendra kumar
> http://www.nabble.com/Exception-in-Search-Result-tf3401621s16610.html#a94726
> 64
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Exception-in-Search-Result-tf3401621s16610.html#a9488529
