[mapguide-users] Viewer API Selection Timing Issues
Buscher, Shane
Shane.Buscher at nngco.com
Thu Mar 15 18:09:09 EDT 2007
Bruce,
Thanks for responding. I did test the Ajax Viewer and it did work. I
do need to use the DWF viewer though. At least I've confirmed the fix
though for Ajax!
Regards,
Shane
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Thursday, March 15, 2007 5:07 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Viewer API Selection Timing Issues
RFC 15 has already been approved and the code changes have already been
submitted.
Please see: http://trac.osgeo.org/mapguide/wiki/MapGuideRfc15
If you build from the source now you will be able to use the new
functionality provided by RFC 15.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Scott
Hameister
Sent: Thu 3/15/2007 3:32 PM
To: 'MapGuide Users Mail List'
Cc:
RFC 15 should solve this problem in the AJAX viewer when/if it
makes it through
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Buscher,
Shane
Sent: Thursday, March 15, 2007 10:02 AM
To: Mapguide_users at lists.osgeo.org
Subject: [mapguide-users] Viewer API Selection Timing Issues
I may be going about this the wrong way, but here's my problem.
I want to select a feature based on an attribute query in the task
pane, automatically zoom to it, and highlight it. I have found
highlighting the feature to be the most problematic because the feature
has to exist within the map frame extent before it can be selected with
the SetSelectionXML() Viewer api function. As far as I know, this is the
only function call you can make in MapGuide to highlight features.
Knowing that SetSelectionXML() will only highlight features in
the current map extent, I preceded to zoom to the feature (ZoomToView)
before calling SetSelectionXML(). The problem is that the map can't
zoom quick enough, and so no features are highlighted:
ZoomToView(x, y, scale);
SetSelectionXML(xmlSet); //no features exist yet because of
delay in ZoomToView
I don't have any problems when the feature already exists in my
map extent. Does anyone have a workaround or better method to
accomplish this? The only hack can think of is to pause the execution
of SetSelectionXML() until ZoomoView is complete, but I'm not sure the
best way to code this.
Regards,
Shane
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070315/b8e731d5/attachment.html
