[mapguide-users] Points added to map at runtime don't display.
Jackie Ng jackie.ng at aecsystems.com.au
Fri Mar 16 00:11:09 EDT 2007
bcales wrote:
> Did you get anywhere with this?
> I have the layer showing, just not the push pins
Wow that was quite some time ago! Anyway, what I found was that I wasn't
careful enough when I was copying the code from the .net viewer sample. I
couldn't honestly tell you what the source of the problem was, even though
when I first copy/pasted I knew *exactly* what the code was supposed to do.
Though when I did this in php it worked the first time without any problems
- Jackie
View this message in context: http://www.nabble.com/Points-added-to-map-at-runtime-don%27t-display.-tf2381361s16610.html#a9508440
