[mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Lionel Goubet lgoubet at GEOMAPGIS.com
Fri Mar 16 08:57:28 EDT 2007
Hi Shane,
All my directories under IIS with mapguide work with ASP.net 2.0.
How add you a reference to the OSGEO.MapGuide assembly in my project ?
Create a directory bin with the dll in
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\bin ?
Thanks for your response
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Buscher, Shane
Envoyé : vendredi 16 mars 2007 13:44
À : MapGuide Users Mail List
Objet : RE: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Lionel,
Check your IIS settings to make sure all of your virtual directories dealing with mapguide are set to aspnet 2.0 by going to properties-->ASP.NET.
Also, make sure you add a reference to the OSGEO.MapGuide assembly in your project.
-shane
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Lionel Goubet
Sent: Friday, March 16, 2007 6:02 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Yes I use IIS
I use ASP.NET 2.0.50727 on a virtual directory 'mapguide'
I don't understand ...
Lionel
De : mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Jackie Ng
Envoyé : vendredi 16 mars 2007 11:58
À : mapguide-users at lists.osgeo.org
Objet : Re: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Hi Lionel,
Is dotnetviewersample an application in IIS?
If so, it is set to use ASP.NET 2.0 and not 1.1?
- Jackie
Lionel Goubet wrote:
> Hi,
> I installed web server extensions with .net and I Installed
> dotnetviewersample under  C:\Program
> but I have this error:
> Erreur de compilation
> Description : Une erreur s'est produite lors de la compilation d'une
> ressource requise pour répondre à cette demande. Veuillez consulter
> ci-dessous les détails relatifs à l'erreur en question, puis modifier
> votre code source de manière appropriée.
> Message d'erreur du compilateur: CS0246: Le type ou le nom d'espace de
> noms 'OSGeo' est introuvable (une directive using ou une référence
> d'assembly est-elle manquante ?)
> Erreur source:
> Ligne 17 : <%@ Import Namespace="System.Collections" %>
> Ligne 18 : <%@ Import Namespace="System.IO" %>
> Ligne 19 : <%@ Import Namespace="OSGeo.MapGuide" %>
> Ligne 20 : <script language="c#" runat="server">
> Ligne 21 :
> Fichier source: c:\Program Files\Map
> WGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx
> Ligne: 19
> What's this error ?
> I add the bin directory but the problem persist
> Thanks .
> mapguide-users mailing list
View this message in context: http://www.nabble.com/-MapguideOpenSource--Error-dotnetviewersample-tf3413674s16610.html#a9512345
