[mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Lionel Goubet lgoubet at GEOMAPGIS.com
Fri Mar 16 09:53:47 EDT 2007
Now I have this message with the user Administrator/admin in a dialog connection :
An unclassified exception occurred.
An unclassified exception occurred. Exception occurred in method new_MgResourceIdentifier at line 681 in file .\MgApi_wrap.cpp
I
De : mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de champingfor
Envoyé : vendredi 16 mars 2007 14:48
À : MapGuide Users Mail List
Objet : Re: RE: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Copy the webconfig.ini from C:\Program Files\MapGuideOpenSource\WebServerExtensions\www to you application directory.
I have copied all the dll of
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin
in the directory
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\bin
The dll are:
ACE.dll
MapGuideDotNetApi.dll
MapGuideUnmanagedApi.dll
MgCoordinateSystem.dll
MgFoundation.dll
MgGeometry.dll
MgHttpHandler.dll
MgMapGuideCommon.dll
MgMdfModel.dll
MgMdfParser.dll
MgPlatformBase.dll
MgWebApp.dll
proj.dll
xerces-c_2_7.dll
I launch the page : http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
It doesn't work, it don't find OSGeo.MapGuide
Help ....
-----Message d'origine-----
De? mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Walt Welton-Lair
Envoy闋: vendredi 16 mars 2007 14:01
罓: MapGuide Users Mail List
Objet? RE: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Yes, you need to make sure you have a copy of the DLLs in ...\www\dotnetviewersample\bin.  Same as what's in ...\www\mapviewernet\bin.
Walt
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Lionel Goubet
Sent: Friday, March 16, 2007 1:57 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Hi Shane,
All my directories under IIS with mapguide work with ASP.net 2.0.
How add you a reference to the OSGEO.MapGuide assembly in my project ?
Create a directory bin with the dll in
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\bin ?
Thanks for your response
De? mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Buscher, Shane
Envoy闋: vendredi 16 mars 2007 13:44
Lionel,
Check your IIS settings to make sure all of your virtual directories dealing with mapguide are set to aspnet 2.0 by going to properties-- >ASP.NET.
Also, make sure you add a reference to the OSGEO.MapGuide assembly in your project.
-shane
Sent: Friday, March 16, 2007 6:02 AM
Yes I use IIS
I use ASP.NET 2.0.50727 on a virtual directory 'mapguide'
I don't understand ...
Lionel
De? mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] De la part de Jackie Ng
Envoy闋: vendredi 16 mars 2007 11:58
罓: mapguide-users at lists.osgeo.org
Objet? Re: [mapguide-users] [MapguideOpenSource] Error dotnetviewersample
Hi Lionel,
Is dotnetviewersample an application in IIS?
If so, it is set to use ASP.NET 2.0 and not 1.1?
- Jackie
Lionel Goubet wrote:
> Hi,
> I installed web server extensions with .net and I Installed
> dotnetviewersample under  C:\Program
> but I have this error:
> Erreur de compilation
> Description : Une erreur s'est produite lors de la compilation d'une
> ressource requise pour r閜ondre ?cette demande. Veuillez consulter
> ci-dessous les d閠ails relatifs ?l'erreur en question, puis modifier
> votre code source de mani鑢e appropri閑.
> Message d'erreur du compilateur: CS0246: Le type ou le nom d'espace de
> noms 'OSGeo' est introuvable (une directive using ou une r閒閞ence
> d'assembly est-elle manquante ?)
> Erreur source:
> Ligne 17 :  <%@ Import Namespace="System.Collections" % >
> Ligne 18 :  <%@ Import Namespace="System.IO" % >
> Ligne 19 :  <%@ Import Namespace="OSGeo.MapGuide" % >
> Ligne 20 :  <script language="c#" runat="server" >
> Ligne 21 :
> Fichier source: c:\Program Files\Map
> WGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx
> Ligne: 19
> What's this error ?
> I add the bin directory but the problem persist
> Thanks .
> mapguide-users mailing list
View this message in context: http://www.nabble.com/-MapguideOpenSource--Error-dotnetviewersample-tf3413674s16610.html#a9512345
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070316/9946862f/attachment-0001.html
