[mapguide-users] mgservice at 100%
George McLean
gmclean at gorge.net
Tue Mar 20 20:24:40 EDT 2007
Thanks Steve,
Thant sounds like good advice.
George
Steve Dang wrote:
> Hi George,
> BDB XML support does not suggest us to delete any file. It's nice if
> that works. I still recommend you to rebuild your database from scratch
> as suggested below, just in case the "fixed" database may still contain
> some bad state that may go back and haunt us later.
> Steve.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
> McLean
> Sent: Tuesday, March 20, 2007 12:53 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] mgservice at 100%
> Thanks Steve,
> I got it fixed per Traian's suggestion.
> I think I need to learn more about BDB!
> I appreciate the help.
> George
> Steve Dang wrote:
>> Hi George,
>> db_checkpoint and db_recover are Oracle BDB XML utilities. I do not
> how
>> well they work and how long it would take to run.
>> It is possible that the repository is corrupt badly due to missing
>> files. If any file gets deleted accidentally, you may not be able to
>> recover your database.
>> Alternately, you could use db_dump and db_load to rebuild your
> database.
>> The documentation can be found under "Utilities" at:
> http://www.oracle.com/technology/documentation/berkeley-db/db/api_cxx/fr
>> ame.html
>> Steve.
>> McLean
>> Sent: Tuesday, March 20, 2007 11:04 AM
>> Is there any way to know approximately how long the cold backup should
>> take? I am running backupofflinerepositories.bat and the CPU has been
> at
>> 100% for about 20 minutes with the db_checkpoint.exe taking all the
> CPU.
>> I see the backupRepositories folder and subfolders but there are no
>> files in them yet.
>> Is it possible the repository database is in a state where the backup
>> does not work? Are there any tools to try and repair it? This is a
>> development system so if I had to rebuild it from scratch that would
> not
>> be a huge loss but it would be good to learn how to fix this sort of
>> problem.
>> Thanks
>> George
>> Steve Dang wrote:
>>> Hi George,
>>> I suggest you to perform a "cold" backup then a restore of the
>>> repositories. The instruction should be under the MapGuide Server
>>> installation directory:
>>> ..\Server\RepositoryAdmin\RepositoryAdmin.pdf
>>> Steve.
>>> McLean
>>> Sent: Monday, March 19, 2007 6:26 PM
>>> Subject: [mapguide-users] mgservice at 100%
>>> I am having problems with mgserver.exe running at 100% in Windows XP.
>>> I tried repair of mgserver and extensions but that did not solve it
> so
>> I
>>> uninstalled extensions and server then reinstalled. This did not
> solve
>>> the problem either.
>>> I found the discussion below and have stopped the service in task
>>> manager and tried running as an application from the command line
>> using
>>> 'mgserver run'. After starting as an application my CPU is still
>> pegged
>>> at 100% with mgserver.exe as the process using all the CPU
>>> Before re-installing I made copy of all the files and folders under
>> the
>>> C:\Program Files\MapGuideOpenSource folder so I am assuming I have
>>> everything backed up.
>>> Should I uninstall and then delete all the repositories etc then
>>> re-install? Any other suggestions?
>>> Thanks
>>> George
>>> Subject:
>>> RE: [mapguide-users] Site corrupt - MG Server fails to start
>>> From:
>>> "Bruce Dechant" <bruce.dechant at autodesk.com>
>>> Date:
>>> Mon, 20 Nov 2006 13:07:36 -0800
>>> To:
>>> <users at mapguide.osgeo.org>
>>> To:
>>>> The files might not actually be corrupt, but may have not been
> closed
>>>> properly (example: due to power outage). When the server starts it
>>>> tries to "clean up" the repositories using the generated log files.
>>>> Under certain circumstances this can take longer then the Windows
>>>> Service Control Manager allows for a service starting up. The thing
>> to
>>>> do in this case is to not run the server as a service and instead
> run
>>>> it interactively as an application to give the server time to
> cleanup
>>>> the repository. Once the repository has been cleaned up you can stop
>>>> the server application and restart it as a service. Note: that you
>>>> should not have to do this under normal operating conditions.
>>>> Bruce
>>>> *From:* Jason Birch [mailto:Jason.Birch at nanaimo.ca]
>>>> *Sent:* November 18, 2006 9:41 PM
>>>> *To:* users at mapguide.osgeo.org
>>>> *Subject:* RE: [mapguide-users] Site corrupt - MG Server fails to
>>> start
>>>> Good cautionary tale.
>>>> If anyone is not backing up their repositories, they should strongly
>>>> consider it. I haven't seen any problems yet, but the repositories
>> are
>>>> file-based and are subject to corruption in the case of interrupted
>>>> writes, etc.
>>>> There is a RepositoryAdmin directory in the Server installation that
>>>> contains some utilities for doing this, and instructions. You can
>> find
>>>> a copy of the isntructions here:
> https://mapguide.osgeo.org/source/browse/*checkout*/mapguide/trunk/MgDev
>>> /Server/RepositoryAdmin/MgOpenSourceRepositoryAdmin.pdf
>>>> Hmm. It would be nice if we could leverage an RDBMS data store to
>>>> store the repository info. This would kinda break the managed data
>>>> idea, but it would eliminate the load balancing problems around
>>>> session access. I don't really like storing my data with the site
>>>> configuration info anyway :)
>>>> Jason
>>>> *From:* Andy Morsell
>>>> *Sent:* Sat 2006-11-18 12:14 PM
>>>> *Subject:* [mapguide-users] Site corrupt - MG Server fails to start
>>>> I have no idea how this happened, but it is rather disconcerting.
>>>> Luckily it was only the Site data that was a problem and that my
>>>> Library seems to be fine. Otherwise I would be reaching into my
>>>> backups to restore from.
>>>> Subject:
>>>> From:
>>>> "Andy Morsell" <amorsell at spatialgis.com>
>>>> Date:
>>>> Mon, 20 Nov 2006 13:13:05 -0800
>>>> To:
>>>> To:
>>>> Thanks for the information Bruce, I'll try that next time I see
> these
>>>> symptoms (hopefully never again). Dave Wilson also mentioned in the
>>>> MapGuide Enterprise discussion group that if the files under Site
> are
>>>> deleted, then server will re-create them when started. I tested this
>>>> and it worked. You will end up losing any users and groups you setup
>>>> (and I'm sure other things, but I don't know exactly what), but I
> was
>>>> pleasantly surprised to see that resource service paths were not
>>>> effected (my repository is not in the default location).
>>>> Andy
>>>> *From:* Bruce Dechant [mailto:bruce.dechant at autodesk.com]
>>>> *Sent:* Monday, November 20, 2006 1:08 PM
>>> start
> closed
>> to
> run
> cleanup
>>>> Bruce
>>> start
>> are
>>>> writes, etc.
>> find
>>>> Jason
>>>> Subject:
>>>> From:
>>>> "Jason Birch" <Jason.Birch at nanaimo.ca>
>>>> Date:
>>>> Mon, 20 Nov 2006 13:18:10 -0800
>>>> To:
>>>> To:
>>>> If you're talking about the same paths that I think you are, they
> are
>>> stored in the serverconfig.ini file.
>>>> Jason
>>>> ________________________________
>>>> From: Andy Morsell
>>>> Sent: Mon 2006-11-20 1:13 PM
>>>> To: users at mapguide.osgeo.org
>>>> Subject: RE: [mapguide-users] Site corrupt - MG Server fails to
> start
> these
>>> MapGuide Enterprise discussion group that if the files under Site are
>>> (and I'm sure other things, but I don't know exactly what), but I was
>>>> Subject:
>>>> From:
>>>> "Brad Nesom" <kidsmake6 at msn.com>
>>>> Date:
>>>> Mon, 20 Nov 2006 15:47:17 -0600
>>>> To:
>>>> To:
>>>> Is there a service or application that could be checked to see if
> the
>>>> cleanup is still running or completed?
>>>> *Sent:* Monday, November 20, 2006 3:08 PM
>>> start
> closed
>> to
> run
> cleanup
>>>> Bruce
>>> start
>> are
>>>> writes, etc.
>> find
>>>> Jason
>>>> Subject:
>>>> From:
>>>> "Steve Dang" <steve.dang at autodesk.com>
>>>> Date:
>>>> Mon, 20 Nov 2006 14:12:25 -0800
>>>> To:
>>>> To:
>>>> No, the server automatically runs this cleanup and completes it at
>>>> startup time. If there is a problem, the server will stop and throw
>> an
>>>> exception.
>>>> Steve.
>>>> *From:* Brad Nesom [mailto:kidsmake6 at msn.com]
>>>> *Sent:* Monday, November 20, 2006 2:47 PM
>>> start
> the
>>> start
> closed
>> to
> run
> cleanup
>>>> Bruce
>>> start
>> are
>>>> writes, etc.
>> find
>>>> Jason
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
