[mapguide-users] WMS and Transparency and multiple support of EPSGs
Axel Dörr
a.doerr at doerrib.de
Wed Mar 21 07:08:28 EDT 2007
Mittwoch, 21.03.2007
Hello List,
I have two questions about Layers on basis of external wms-services as datasource:
1. Transparency of Layers
Testing external wms-services i created the dataconnection and two or three layers
showing different data from the same external wms-server. So far everything is fine.
In the map and the weblayout i created i can show the layers, but the layers seem to
be opaque. I told the backgroundcolor to be transparent. And im quite sure, that the
service delivers transparent layers.
Is it possible in MGOS 1.1.0 two have transparent layers based on external wms?
2. WMS which support several EPSG
I want to connect to an external wms-server. The connection works fine. The
preview of the layers shows up the right content. But only with EPSG:4326
and not with the also supported EPSG:31467. Within a map with the definition
of EPSG:31467 als coordinate system an the correct boundaries in Studio
i see nothing.
For example this is the case with the following wms:
http://rips-uis.lubw.baden-wuerttemberg.de/wms/cgi/UIS_0100000006900001
Is there a solution for this problem?
Thanks for help!
Axel
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070321/35066da8/attachment.html
