[mapguide-users] Newbie learning to insert images
Krunoslav
a_krunoslav at gmx.net
Thu Mar 22 08:40:52 EDT 2007
Krunoslav wrote:
> Thank you again Frank. Everything works fine now. I did everything as you
> suggested, and images are shown at their location. Tileindex mechanism
> would be great, since it's really painful to work with such large size
> images. Although I have good computer, working with Tiffs over 1GB size is
> not easy job. Anyway, it works, and performance over LAN is totally
> acceptable. However, I would like to make another map instance, which
> would be accessible from internet. I know I will have to sacrifice quality
> for performance, but anyway...
> What would you suggest for such task? TIFF's with jpeg compression? Or
> just jpeg's? Is it even possible to have georeferenced jpeg's?
Well, I will answer myself :)
I played a lot with this images, and now I'm satisfied with performance,
even when accessing the map via slow internet link. What I did is, as Frank
suggested: merged Tiffs (as possible pieces as my machine could handle),
then prepared them (added overview and convert them to tiled tiffs),
configured path to those images, and it works. Performance is satisfying.
Only thing I added (which Frank didn't mention), is that I changed
GETDYNAMICMAPOVERLAYIMAGE format from PNG to JPG. This really helps a lot to
load aerial photos, which contain a lot of colors.
Thank you again Frank. My problem is solved now, and I can move on further
in exploring possibilities of this beautiful product, MGOS.
View this message in context: http://www.nabble.com/Newbie-learning-to-insert-images-tf3423856s16610.html#a9611843
