[mapguide-users] RE: MGOS Application Overlaying on GOOGLE
Dhirendra Kumar dhirendra.mgos at gmail.com
Sat Mar 24 07:39:16 EDT 2007
Hi Andy Morsell,
Thankyou for your valuable replay, according to you, first i uninstalled
MapGuide 1.0.2 and install 1.1.0 and as per your suggestion open file
http://com008:8008/mapguide/MapAgent/index.html/ and  click on KML option
and GetMapKml and fillup all information, when i click on subbmit button
then my maps automatically overlap on Google earth with their right
projection ( So i am verry happy to see this). But my problem is, when i
want to see my maps on google earth then every time i have to open mapagent
and manually click on Subbmit button. But my client want to click on one
link (not manually) and google earth display map automatically. So for that
resion i want  to know mapagent  generate .KML file in which place and by
default which name (i want to give name manuall then what i have to do). So
please suggest me. i am waiting
........................................................, thankyou once
again for your valuable information.
Thanking you
Dhirendra Kumar
Andy Morsell wrote:
> MapGuide Open Source 1.1.0 has the capability "out of the box".  There is
> no
> documentation, but it's pretty straight-forward to utilize by issuing
> operation requests directly against the mapagent.  To try it out, load up
> the mapagent test page
> (http://YOURSERVERNAME:PORT/mapguide/MapAgent/index.html).  Then, in the
> upper-left pane click on Kml.  Then, go to the GetMapKml, GetLayerKml, or
> GetFeaturesKml options.  Here's the results of issuing the default
> operations from that interface:
> http://YOURSERVERNAME:PORT/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPK
> ML&VERSION=1.0.0&FORMAT=KML&DPI=96&MAPDEFINITION=Library%3A%2F%2FSamples%2FS
> heboygan%2FMaps%2FSheboygan.MapDefinition
> http://YOURSERVERNAME:PORT/mapguide/mapagent/mapagent.fcgi?OPERATION=GETLAYE
> RKML&VERSION=1.0.0&FORMAT=KML&DPI=96&DRAWORDER=0&LAYERDEFINITION=Library%3A%
> 2F%2FSamples%2FSheboygan%2FLayers%2FParcels.LayerDefinition&BBOX=-87.7398334
> 220901%2C43.73822699224595%2C-87.72068284176505%2C43.75068777906662&WIDTH=79
> 6&HEIGHT=717
> http://YOURSERVERNAME:PORT/mapguide/mapagent/mapagent.fcgi?OPERATION=GETFEAT
> URESKML&VERSION=1.0.0&FORMAT=KML&DPI=96&DRAWORDER=0&LAYERDEFINITION=Library%
> 3A%2F%2FSamples%2FSheboygan%2FLayers%2FParcels.LayerDefinition&BBOX=-87.7398
> 334220901%2C43.73822699224595%2C-87.72068284176505%2C43.75068777906662&WIDTH
> =796&HEIGHT=717
> There's also ways to do cool KML things via the MGOS and FDO API's, but
> these are obiously more advanced.  For an example, see these pages:
> http://earth.nanaimo.ca/
> http://www.spatialgis.com/demo.html
> http://mapguide.osgeo.org/livegallery.html
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
> Sent: Friday, March 23, 2007 6:12 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGOS Application Overlaying on GOOGLE
> Unfortunately I don't know anything about this.  Perhaps someone else will
> jump in here?
> Paul
> On 23-Mar-07, at 2:29 AM, Dhirendra Kumar wrote:
>> Hi Paul,
>> Thank you for replay, But i have no idea how to use MapGuide as a KML
>> server. If you have any information then please give me.
>> Thankyou in advance
>> Dhirendra kumar
>> Paul Spencer-5 wrote:
>>> Dhirendra,
>>> This is probably a difficult thing to do ... I think you can use
>>> MapGuide as a KML server for Google Earth.  I'm not sure if Google
>>> Maps can load KML directly yet.
>>> You can also look at using OpenLayers (http://www.openlayers.org) to
>>> build your web client since it can use Google Maps API to load Google
>>> maps and then overlay other layers (using WMS for instance).  You
>>> could probably launch an OpenLayers app from MapGuide, but again,
>>> it's not going to be trivial to set up.
>>> Cheers
>>> Paul
>>> On 22-Mar-07, at 8:06 AM, Dhirendra Kumar wrote:
>>>> Hi All,
>>>> I devloped GIS Election Application using MGOS and now i want to
>>>> overlaying my application on Google. Requirment is when user will
>>>> click on link of right pane of Ajaxviewer then map's are displaying
>>>> in central window get overlapped on GOOGLE with their right Position
>>>> and preserve shape.
>>>> But i
>>>> have no idea about this, So Any Boady Please help me. I am
>>>> waiting...........................................................
>>>> Thankyou in advance
>>>> Dhirendra Kumar
>>>> View this message in context: http://www.nabble.com/MGOS-
>>>> Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9611820
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>> |Chief Technology Officer                                         |
>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9629094
View this message in context: http://www.nabble.com/MGOS-Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9649073
