[mapguide-users] MGOS and Google Earth - KML support
Jason Birch Jason.Birch at nanaimo.ca
Tue Mar 27 11:50:52 EDT 2007
In order to work in Google Earth, MapGuide needs to know how to
transform the data to LL84.  If you don't set the correct projection for
your data , it has no way of doing this.  The coordinate system that you
choose depends on what your initial data is in.
Jason
-----Original Message-----
Subject: [mapguide-users] MGOS and Google Earth - KML support
1. I use coordinate system: *XY-M* (Arbitrary X-Y Coordinates (Meters))
what coordinate system should i chose from MG Studio?
is it posible that my map can't be display in Google Earth? How can i
transform mapfiles?
