[mapguide-users] Re: mapguide-users Digest, Vol 3, Issue 121
Traian Stanev
traian.stanev at autodesk.com
Thu Mar 29 11:22:34 EDT 2007
You can try running ldd -r on the Mapguide executable to see if indeed
it is missing some function from curl.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Casey
Townsend
Sent: Thursday, March 29, 2007 11:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: mapguide-users Digest, Vol 3, Issue 121
Thanks for the reply Walt. I have a symlink from libcurl.so.2 that I
added, everything else looks the same:
(didn't work with or without the so.2 link)
[root at mapguidedev lib]# pwd
/usr/lib
[root at mapguidedev lib]# ls -al|less
<snip>
-rw-r--r-- 1 root root 255310 Dec 20 2005 libcurl.a
lrwxrwxrwx 1 root root 16 Mar 27 16:11 libcurl.so ->
libcurl.so.3.0.0
lrwxrwxrwx 1 root root 16 Mar 28 16:48 libcurl.so.2 ->
libcurl.so.3.0.0
lrwxrwxrwx 1 root root 16 Mar 27 15:34 libcurl.so.3 ->
libcurl.so.3.0.0
-rwxr-xr-x 1 root root 192768 Dec 20 2005 libcurl.so.3.0.0
</snip>
For the record, the error is:
(from /media/cdrom/web# ./setup)
<snip>
D: opening db index
/usr/lib/rpmdb/i386-redhat-linux/CentOS/Packages rdonly mode=0x0
D: opening db index
/usr/lib/rpmdb/i386-redhat-linux/CentOS/Providename rdonly mode=0x0
D: Requires: libcurl.so.2 NO
D: package mapguideenterprise2007-webextension-1.0.0.17804-1.i386 has
unsatisfied Requires: libcurl.so.2
D: read h# 498 Header V3 DSA signature: OK, key ID 443e1821
</snip>
<snip>
D: closed db index /var/lib/rpm/Basenames
D: closed db index /var/lib/rpm/Packages
D: closed db environment /var/lib/rpm/Packages
error: Failed dependencies:
libcurl.so.2 is needed by
D: ========== recording tsort relations
D: Requires: libACE.so.5.4.0 YES (added
provide)
D: ignore package name relation(s) [0] libtermcap -> bash
D: ignore package name relation(s) [1] modutils -> vixie-cron
D: ignore package name relation(s) [2] ypbind -> yp-tools
</snip>
Date: Wed, 28 Mar 2007 20:09:24 -0400
From: "Walt Welton-Lair" <walt.welton-lair at autodesk.com>
Subject: RE: [mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
<A4F4647B12DBAD40B07041547CA2526408F6538E at msgusaebk01.autodesk.com>
Content-Type: text/plain; charset="us-ascii"
What does the libcurl.so symlink point to? It should look something
like the following:
-rw-r--r-- 1 284100 Dec 12 2005 libcurl.a
lrwxrwxrwx 1 16 Mar 13 22:24 libcurl.so -> libcurl.so.3.0.0
lrwxrwxrwx 1 16 Mar 13 22:24 libcurl.so.3 -> libcurl.so.3.0.0
-rwxr-xr-x 1 214952 Dec 12 2005 libcurl.so.3.0.0
This is from a Fedora 4 machine, and I run MG OpenSource on it w/o
problems.
Walt
Townsend
Sent: Thursday, March 29, 2007 2:02 AM
Subject: [mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
I'm trying to run MapGuide Enterprise on centos4.4
<http://www.centos.org/> which is the equivalent to RHEL 4.
Yes, I know it is setup for RHEL 3, but the only problem seems to be
that libcurl.so.2 has been replaced by libcurl.so.3. Reading the cURL
list - the API didn't change, mostly just deprecated packages were
removed.
I tried creating a symlink in /usr/lib/ from libcurl.so.2 to
libcurl.so.3 and when that didn't work to libcurl.so.3.0.0. That
didn't
work either.
Any suggestions (other than use RHEL 3 !) ?
Casey Townsend
System Administrator
Department of Transportation
City of Tucson
casey.townsend at tucsonaz.gov
520-837-6663
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
