[mapguide-users] Re: RHEL4 - libcurl problem (titlecorrected)
Casey Townsend Casey.Townsend at tucsonaz.gov
Thu Mar 29 12:28:22 EDT 2007
I successfully installed MapGuide Server (/media/cdrom/server# ./setup)
after I manually installed libstdc++.so.5 (yum install libstdc++.so.5).
I'm now trying to install the Web Server Extensions.
The full output of /media/cdrom/web# ./setup is below. The specific
error is:
error: Failed dependencies:
        libcurl.so.2 is needed by
mapguideenterprise2007-webextension-1.0.0.17804-1.i386
I'm sorry I don't know how to extract the rpm from the .bin file.
Thanks so much for your help.
[root at mapguidedev /media/cdrom/web]# ./setup
Do you agree to the above license terms? [yes or no]
yes
Unpacking...
Checksumming...
Done.
D: ==============
/root/mapguideenterprise2007-webextension-1.0.0.17804-1.i386.rpm
D: Expected size:    107877350 =
lead(96)+sigs(180)+pad(4)+data(107877070)
D:   Actual size:    107877350
D: /root/mapguideenterprise2007-webextension-1.0.0.17804-1.i386.rpm:
MD5 digest: OK (5ae8abda733b3efdd3a9e9e23c07324e)
D:      added binary package [0]
D: found 0 source and 1 binary packages
D: opening  db environment /var/lib/rpm/Packages joinenv
D: opening  db index       /var/lib/rpm/Packages rdonly mode=0x0
D: locked   db index       /var/lib/rpm/Packages
D: ========== +++ mapguideenterprise2007-webextension-1.0.0.17804-1
i386/linux 0x1
D: opening  db index       /var/lib/rpm/Depends create mode=0x0
D: opening  db index       /var/lib/rpm/Basenames rdonly mode=0x0
D: opening  db index       /var/lib/rpm/Pubkeys rdonly mode=0x0
D:  read h#     662 Header sanity check: OK
D: ========== DSA pubkey id a53d0bab443e1821
D:  read h#      40 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: /bin/sh                                       YES (db
files)
D:  read h#      49 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: /usr/bin/perl                                 YES (db
files)
D:  Requires: libACE.so.5.4.0                               YES (added
provide)
D:  Requires: libCsmap.so.1                                 YES (added
provide)
D:  Requires: libMgCommon.so.7                              YES (added
provide)
D:  Requires: libMgCoordinateSystem.so.7                    YES (added
provide)
D:  Requires: libMgHttpHandler.so.7                         YES (added
provide)
D:  Requires: libMgMdfModel.so.7                            YES (added
provide)
D:  Requires: libMgMdfParser.so.7                           YES (added
provide)
D:  Requires: libMgWebApp.so.7                              YES (added
provide)
D:  Requires: libapr-0.so.0                                 YES (added
provide)
D:  Requires: libaprutil-0.so.0                             YES (added
provide)
D: opening  db index       /var/lib/rpm/Providename rdonly mode=0x0
D:  read h#      12 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libc.so.6                                     YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.0)                          YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.1)                          YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.1.2)                        YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.1.3)                        YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.2)                          YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.2.3)                        YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.3)                          YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.3.2)                        YES (db
provides)
D:  Requires: libc.so.6(GLIBC_2.3.3)                        YES (db
provides)
D:  read h#     737 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libcom_err.so.3                               YES (db
provides)
D:  Requires: libcrypt.so.1                                 YES (db
provides)
D:  Requires: libcrypt.so.1(GLIBC_2.0)                      YES (db
provides)
D:  read h#     663 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libcrypto.so.4                                YES (db
provides)
/usr/lib/rpmdb/i386-redhat-linux/CentOS/Packages joinenv
D: opening  db index
/usr/lib/rpmdb/i386-redhat-linux/CentOS/Packages rdonly mode=0x0
D: opening  db index
/usr/lib/rpmdb/i386-redhat-linux/CentOS/Providename rdonly mode=0x0
D:  Requires: libcurl.so.2                                  NO
D: package mapguideenterprise2007-webextension-1.0.0.17804-1.i386 has
unsatisfied Requires: libcurl.so.2
D:  read h#     498 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libdb-4.1.so                                  YES (db
provides)
D:  Requires: libdl.so.2                                    YES (db
provides)
D:  Requires: libdl.so.2(GLIBC_2.0)                         YES (db
provides)
D:  Requires: libdl.so.2(GLIBC_2.1)                         YES (db
provides)
D:  read h#      20 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libexpat.so.0                                 YES (db
provides)
D:  Requires: libfcgi.so.0                                  YES (added
provide)
D:  read h#     665 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libgcc_s.so.1                                 YES (db
provides)
D:  Requires: libgcc_s.so.1(GCC_3.0)                        YES (db
provides)
D:  Requires: libgcc_s.so.1(GLIBC_2.0)                      YES (db
provides)
D:  read h#      21 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libgdbm.so.2                                  YES (db
provides)
D:  read h#      73 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libgssapi_krb5.so.2                           YES (db
provides)
D:  Requires: libk5crypto.so.3                              YES (db
provides)
D:  Requires: libkrb5.so.3                                  YES (db
provides)
D:  Requires: libm.so.6                                     YES (db
provides)
D:  Requires: libm.so.6(GLIBC_2.0)                          YES (db
provides)
D:  Requires: libnsl.so.1                                   YES (db
provides)
D:  Requires: libpthread.so.0                               YES (db
provides)
D:  Requires: libpthread.so.0(GLIBC_2.0)                    YES (db
provides)
D:  Requires: libpthread.so.0(GLIBC_2.1)                    YES (db
provides)
D:  Requires: libpthread.so.0(GLIBC_2.1.1)                  YES (db
provides)
D:  Requires: libpthread.so.0(GLIBC_2.2)                    YES (db
provides)
D:  Requires: libpthread.so.0(GLIBC_2.3.2)                  YES (db
provides)
D:  Requires: libresolv.so.2                                YES (db
provides)
D:  Requires: libresolv.so.2(GLIBC_2.0)                     YES (db
provides)
D:  Requires: libresolv.so.2(GLIBC_2.2)                     YES (db
provides)
D:  Requires: librt.so.1                                    YES (db
provides)
D:  Requires: librt.so.1(GLIBC_2.1)                         YES (db
provides)
D:  Requires: libssl.so.4                                   YES (db
provides)
D:  read h#     729 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libstdc++.so.5                                YES (db
provides)
D:  Requires: libstdc++.so.5(CXXABI_1.2)                    YES (db
provides)
D:  Requires: libstdc++.so.5(GLIBCPP_3.2)                   YES (db
provides)
D:  Requires: libstdc++.so.5(GLIBCPP_3.2.2)                 YES (db
provides)
D:  read h#      17 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libuuid.so.1                                  YES (db
provides)
D:  Requires: libxerces-c.so.27                             YES (added
provide)
D:  read h#     204 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libxml2.so.2                                  YES (db
provides)
D:  read h#      60 Header V3 DSA signature: OK, key ID 443e1821
D:  Requires: libz.so.1                                     YES (db
provides)
D:  Requires: perl >= 0:5.003                               YES (db
provides)
D:  Requires: perl(AnyDBM_File)                             YES (db
provides)
D:  Requires: perl(Fcntl)                                   YES (db
provides)
D:  Requires: perl(strict)                                  YES (db
provides)
D:  Requires: rpmlib(CompressedFileNames) <= 3.0.4-1        YES (rpmlib
provides)
D:  Requires: rpmlib(PayloadFilesHavePrefix) <= 4.0-1       YES (rpmlib
provides)
D: opening  db index       /var/lib/rpm/Conflictname rdonly mode=0x0
D: closed   db index       /var/lib/rpm/Pubkeys
D: closed   db index       /var/lib/rpm/Depends
D: closed   db index       /var/lib/rpm/Conflictname
D: closed   db index       /var/lib/rpm/Providename
D: closed   db index       /var/lib/rpm/Basenames
D: closed   db index       /var/lib/rpm/Packages
D: closed   db environment /var/lib/rpm/Packages
D: ========== recording tsort relations
provide)
D: ignore package name relation(s) [0]  libtermcap -> bash
D: ignore package name relation(s) [1]  modutils -> vixie-cron
D: ignore package name relation(s) [2]  ypbind -> yp-tools
D: ignore package name relation(s) [3]  ghostscript-fonts ->
ghostscript
D: ignore package name relation(s) [4]  libgnomeprint15 -> gnome-print
D: ignore package name relation(s) [5]  nautilus -> nautilus-mozilla
D: ignore package name relation(s) [6]  tcl -> postgresql-tcl
D: ignore package name relation(s) [7]  arts -> kdelibs-sound
D: ignore package name relation(s) [8]  pango-gtkbeta-devel ->
pango-gtkbeta
D: ignore package name relation(s) [9]  XFree86 -> Mesa
D: ignore package name relation(s) [10] compat-glibc -> db2
D: ignore package name relation(s) [11] compat-glibc -> db1
D: ignore package name relation(s) [12] pam -> initscripts
D: ignore package name relation(s) [13] initscripts -> sysklogd
provide)
provide)
provide)
provide)
provide)
provide)
provide)
provide)
provide)
provide)
provide)
D: ========== tsorting packages (order, #predecessors, #succesors,
tree, depth)
D:     0    0    0    0    0
+mapguideenterprise2007-webextension-1.0.0.17804-1
D: closed   db index
D: closed   db index
>>> "Traian Stanev" <traian.stanev at autodesk.com> 3/29/2007 9:10 AM >>>
You need to try it on the "mgserver" executable, not the rpm. Actually
we need to backtrack a little. Does rpm even install mapguide or does
it
complain about the missing dependency?
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Casey
Townsend
Sent: Thursday, March 29, 2007 12:00 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Re: RHEL4 - libcurl problem
(titlecorrected)
Thanks for teaching me something new, but it didn't work:
[root at mapguidedev web]# pwd
/media/cdrom/web
[root at mapguidedev web]# ldd -r
mapguideenterprise2007-webextension-1.0.0.17804-1.i386-rpm.bin
        not a dynamic executable
Probably, I just don't understand how do this correctly?
>>> "Traian Stanev" <traian.stanev at autodesk.com> 3/29/2007 8:22 AM >>>
You can try running ldd -r on the Mapguide executable to see if indeed
it is missing some function from curl.
Traian
Townsend
Sent: Thursday, March 29, 2007 11:11 AM
Subject: [mapguide-users] Re: mapguide-users Digest, Vol 3, Issue 121
Thanks for the reply Walt. I have a symlink from libcurl.so.2 that I
added, everything else looks the same:
(didn't work with or without the so.2 link)
[root at mapguidedev lib]# pwd
/usr/lib
[root at mapguidedev lib]# ls -al|less
<snip>
-rw-r--r--    1 root root      255310 Dec 20  2005 libcurl.a
lrwxrwxrwx    1 root root          16 Mar 27 16:11 libcurl.so ->
libcurl.so.3.0.0
lrwxrwxrwx    1 root root          16 Mar 28 16:48 libcurl.so.2 ->
libcurl.so.3.0.0
lrwxrwxrwx    1 root root          16 Mar 27 15:34 libcurl.so.3 ->
libcurl.so.3.0.0
-rwxr-xr-x    1 root root      192768 Dec 20  2005 libcurl.so.3.0.0
</snip>
For the record, the error is:
(from /media/cdrom/web# ./setup)
<snip>
D: opening  db index
D: opening  db index
</snip>
<snip>
provide)
</snip>
Date: Wed, 28 Mar 2007 20:09:24 -0400
From: "Walt Welton-Lair" <walt.welton-lair at autodesk.com>
Subject: RE: [mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
<A4F4647B12DBAD40B07041547CA2526408F6538E at msgusaebk01.autodesk.com>
Content-Type: text/plain;	charset="us-ascii"
What does the libcurl.so symlink point to?  It should look something
like the following:
-rw-r--r--  1 284100 Dec 12  2005 libcurl.a
lrwxrwxrwx  1     16 Mar 13 22:24 libcurl.so -> libcurl.so.3.0.0
lrwxrwxrwx  1     16 Mar 13 22:24 libcurl.so.3 -> libcurl.so.3.0.0
-rwxr-xr-x  1 214952 Dec 12  2005 libcurl.so.3.0.0
This is from a Fedora 4 machine, and I run MG OpenSource on it w/o
problems.
Walt
Townsend
Sent: Thursday, March 29, 2007 2:02 AM
Subject: [mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
I'm trying to run MapGuide Enterprise on centos4.4
<http://www.centos.org/> which is the equivalent to RHEL 4.
Yes, I know it is setup for RHEL 3, but the only problem seems to be
that libcurl.so.2 has been replaced by libcurl.so.3. Reading the cURL
list - the API didn't change, mostly just deprecated packages were
removed.
I tried creating a symlink in /usr/lib/ from libcurl.so.2 to
libcurl.so.3 and when that didn't work to libcurl.so.3.0.0. That
didn't
work either.
Any suggestions (other than use RHEL 3 !) ?
Casey Townsend
System Administrator
Department of Transportation
City of Tucson
casey.townsend at tucsonaz.gov
520-837-6663
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
