[mapguide-users] RE: RE: checking wms connections
Chris Claydon
chris.claydon at autodesk.com
Thu Mar 29 15:57:37 EDT 2007
You should check that your WMS server name is configured correctly via
the Site Administrator interface:
http://<yourserver:yourport>/mapguide/mapadmin/login.php
Click on the "Configure WMS" link and make sure that "Server name:" is
set to the correct server and port. In order to support remote WMS
clients, it should not be set to localhost or 127.0.0.1.
Chris.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of spaceoddity
Sent: March 29, 2007 1:42 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: RE: checking wms connections
I turned off my custom layers and turned on Sheboygan. My
GetCapabilities
now looks identical to a site that I found on the list that works in
ArcGIS
and Udig (mapguide.spatialgis.com).
One difference I see in our implementations is they use port 80 and I
use
8008. Could my choice of 8008 at install time have messed up anything?
I'm
port forwarding through a little router. Is there anything I might have
messed up on the Windows user setups? I've got Permissions on the
Service
and layer set to Everyone.
Andy Morsell wrote:
> I can see my MGOS derived WMS layers in ArcMap 9.2. If you have the
> sample
> Sheboygan dataset loaded, you should be able right click on that layer
> name
> in ArcMap and select Zoom to Layer. If you have setup your own layers
> exposed via WMS and can't see them, the data may still be drawing but
is
> very small and you may have to manually zoom into that area. Be sure
to
> enter a limiting area in the Bounds parameter for your WMS setup in
> MapGuide
> Studio. If you are using <Bounds SRS="EPSG:4326" west="-180"
south="-90"
> east="180" north="90" /> then ArcMap is going zoom to the entire
world.
> Andy
> From: mapguide-users-bounces at lists.osgeo.org
spaceoddity
> Sent: Thursday, March 29, 2007 7:24 AM
> Subject: [mapguide-users] RE: checking wms connections
> I'm trying to view my MGOS WMS service in ArcMap9.2 or uDig 1.18.
Both
> receive and process the capabilities info but neither draw the layer.
I'm
> able to manually request a map based on your helpful test tool which
> generates
http://neomatix.linksysnet.com:8008/mapguide/mapagent/mapagent.fcgi?requ
est=
GetMap&service=WMS&layers=Tiger/Layers/places2&srs=EPSG:4326&bbox=-87.74
,43.
> 68,-87.69,43.815&width=500&height=500&format=image/png
> but ArcMap just draws a blank and uDIG says RenderingConnection
refused:
> connect
> Any hints on what else to look for?
> Andy Morsell wrote:
>> What do you get from this?
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?REQUEST=GetCapab
>> ilitie
>> s&SERVICE=WMS&FORMAT=text/xml
>> Also attached is an email from Thomas Tuerke from July that has handy
>> little wms client test page in it. I hope it comes through on the
>> email list.
>> Andy
>> From: joanne cook [mailto:j.cook at oxfordarch.co.uk]
>> Sent: Monday, November 13, 2006 7:40 AM
>> To: users at mapguide.osgeo.org
>> Subject: [mapguide-users] checking wms connections
>> Hi All,
>> I am trying to make a wms connection to some layers in my MapGuide
>> OpenSource 1.0.2 map. I can't connect to my own, and assume there's
>> some kind of problem with the conversion from a different coordinate
>> system, as seems to have been discussed at length on this list, so I
>> thought I'd better try the Sheboygan data first. All I am trying to
do
>> is connect to the data in Firefox 2, using the following URL:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSIO
N=1.
1.1&REQUEST=GetMap&LAYERS=Samples/Sheboygan/Layers/Buildings&FORMAT=im
>> age/pn
>> g
>> This gives me the following message:
>> An unclassified exception occurred.
>> An unclassified exception occurred. Exception occurred in method
>> MgHttpWmsGetMap.Execute at line 204 in file
c:\build_tux_area\mgdev_opensource\web\src\httphandler\HttpWmsGetMap.c
>> pp
>> If I remove any of the parameters I get an xml document back that
>> tells me I don't have all the parameters I need. A GetCapabilities
>> request seems to validate as far as I can tell...
>> The end result of all of this is that I want to be able to use my
>> MapGuide Open Source data in OpenLayers, but needless to say that
>> doesn't work at all at the moment either!
>> Many thanks
>> Jo
>> Joanne Cook BSc MLitt AIFA MBCS
>> Information Systems Coordinator
>> Oxford Archaeology North
>> This message has been scanned for viruses by BlackSpider MailControl
>> www.blackspider.com
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> Ivan, Joanne,
>> Shared sympathies on that 559 response. It's a catch-all response,
>> theoretically "of last resort."
>> Joanne: in regards to WMS, let me rephrase Ivan's response a bit:
>> "Welcome to the joys of interoperability." When you're doing WMS,
>> you're at the mercy of several implementations (plus conditions on
the
>> network, etc.)
>> Strictly speaking, a proper WMS request is:
>> http://someurl?request=GetCapabilities&service=WMS
>> in order to learn the capabilities of the server (where, as you might
>> expect "someurl" is to be replaced by the URL of the server in
>> question.) The next step is typically
>> http://someurl?request=GetMap&a-bunch-of-specific-parameters
>> where the parameters are determined by what you learned from
>> GetCapabilities.
>> Depending on the client, you might get away with just providing the
>> http://someurl part; the client's UI will then guide you through the
>> selection of layers, styles, and all that.
>> Other -- lower-level -- clients require you to literally type out the
>> entire http://someurl?request=GetMap&etc request. This has the
>> unfortunate effect of placing an (undue?) burden of WMS
sophistication
>> on the user.
>> To that end, I've attached a little HTML web page that helps
somewhat...
>> in that you can play with the various parameters on the web page.
>> When you have something you want, you can copy the URL into the
>> client's edit control. It's not the most sophisticated thing out
>> there, but for 3K of text, it does a workable job.
>> - Thomas
>> From: Ivan Milicevic [mailto:ivan at ineo.hr]
>> Sent: Wednesday, July 05, 2006 7:29 AM
>> Subject: RE: [mapguide-users] Having trouble figuring out the path
for
>> wms
>> Wellcome to the hell of "error: (559) MgFdoException" :-)
>> Sent: 5. srpanj 2006 16:26
>> Subject: [mapguide-users] Having trouble figuring out the path for
wms
>> Hi All,
>> I am trying to use Autodesk MapGuide Studio to connect to a wms
>> server, powered by MapServer, using the latest wms/wfs connectors,
but
>> I can't seem to figure out the path and can't find any documentation
>> on this. The MapServer documentation suggests a path something like
>> http://yourhost/cgi-bin/mapserv.exe?map=path/to/your/map&
>> With a whole bunch of extra parameters after it, whereas a MapGuide
>> Studio connection to (say) geoserver seems only to require
>> http://yourhost/geoserver/wms <http://yourhost/geoserver/wms>
>> The first option gives me an error that states
>> System.Net.WebException: The remote server returned an error: (559)
>> MgFdoException.
>> at
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetReq
>> uestTo
>> String(Operation operation)
>> at
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(Strin
>> g resourceId, String provider, String connectionString)
>> at
Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>> Which is fair enough since I didn't think it was correct, but has
>> anyone managed to make a connection from Studio to a MapServer map,
>> and what path did they use?
>> Many thanks
>> Jo
>> www.blackspider.com
>> Simple WMS Client
>> body {
>> background-color: #eee;
>> .frame {
>> border: 1px solid red;
>> Simple WMS Client
>> Provide the desired values at left, then click the Update button
>> to see the image here.
>> Site
>> Layers
>> SRS
>> BBOX
>> WIDTH
>> HEIGHT
>> FORMAT
>> use Service=WMS
http://www.nabble.com/checking-wms-connections-tf2623055s16610.html#a973
4357
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/checking-wms-connections-tf2623055s16610.html#a974
1174
