[mapguide-users] Mapguide server configuration
Haris Kurtagic haris at sl-king.com
Sat Mar 31 13:39:31 EDT 2007
Are you trying with latest version 0.6.4 of provider ?
I suppose this behaviour you get in situation with multiple users or when you start one request and before that request finishes you start another one ?
We saw simillar behaviour but mainly when updating and inserting data.
I made some changes in 0.6.4 but I think it didn't solved all the problems.
I don't think yet that it is a main reason but we find out that if we disable MapGuide connection pooling it is working ok.
So I have a version of provider which does caching inside, so it will run with same speed if you disable MG caching.
I can send you ( in a couple days) that version of provider to try.
Anyhow we will try to figure out what is causing a problems, it is very high on my list.
Haris
From: mapguide-users-bounces at lists.osgeo.org on behalf of abbas
Sent: Sat 3/31/2007 7:36 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide server configuration
Now, i'm working with mapguide opensource+ asp.net <http://asp.net/>  under IIS 6.0 and windows server enterprise 2003. i'm using king FDO to access oracle spatial 10gR2 but it's seems poor performance. After few minute query and select feature, web browser not responding and seems mapguide server die, so i need to restart Mapguide server .my hardware spesification is  Dual Xeon 5130 @ 2 GHz and 4 GB Memory. I need suggestion how to configure mapguide server or send to me file serverconfig .
Thanks.
Andi Baso Annas
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070331/715ab061/attachment.bin
