[mapguide-users] my map can not be displayed in map preview
Jackie Ng jackie.ng at aecsystems.com.au
Wed May 2 19:24:57 EDT 2007
If you create a weblayout resource with that map and preview the weblayout,
does it show then?
If not, are the extents on the map correct?
Also what provider are you using for your feature sources? sdf? shp?
- Jackie
fishtrees wrote:
> hi I create a map ,but it doesn't display in preview frame,only display
> backgoud color. I have checked data source,it can work good because when I
> edit a layer in my map,the preview frame displaying the preview of layer.
> Is the problem coordinate system setting? In MapInfo,the coordinate system
> is longitude/latitude(WGS 84),CoordSys Earth Projection 1, 104 , but I
> can't find it in MapGuide Studio when editing a map. If the problem isn't
> the coordinate system,what cause it? Thanks fishtrees
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/my-map-can-not-be-displayed-in-map-preview-tf3682811s16610.html#a10296637
