[mapguide-users] Re: Mapguide 1.20 beta1 Webstudio Error
Kenneth ks at geograf.dk
Thu May 3 12:28:20 EDT 2007
That looks like a IPv6 address... Not sure what this has to do with
webstudio though...
Regards, Kenneth, GEOGRAF A/S
Zac Spitzer wrote:
> i have resolved this by changing from
> the config.xml
> to
> <StudioLiteConfig>
>  <DefaultSite>http://127.0.0.1:8008/mapguide</DefaultSite>
>  <DefaultUserName>Administrator</DefaultUserName>
>  <DefaultTechnology>php</DefaultTechnology>
> </StudioLiteConfig>
> my ping localhost resolves to ::1:
> a
> On 5/3/07, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> I am having trouble with Mapguide Webstudio using the 1.20 beta1
>> running on xp sp2... firewall disabled
>> clean install of mapguide... bundled php options
>> the mapguide site administrator works fine
>> but the webstudio doesn't load properly (ie the site explorer)
>> I have the Sheboygan.mgp package loaded via the site administrator and
>> i can view it via the php sample viewer
>> here's my apache error log
>> [Thu May 03 15:49:17 2007] [notice] Apache/2.0.55 (Win32)
>> mod_fastcgi/2.4.2 mod_jk/1.2.15 configured -- resuming normal
>> operations
>> [Thu May 03 15:49:17 2007] [notice] Server built: Oct  9 2005 19:16:56
>> [Thu May 03 15:49:17 2007] [notice] Parent: Created child process 8696
>> [Thu May 03 15:49:17 2007] [notice] Child 8696: Child process is running
>> [Thu May 03 15:49:18 2007] [notice] Child 8696: Acquired the start
>> mutex.
>> [Thu May 03 15:49:18 2007] [notice] FastCGI: process manager initialized
>> [Thu May 03 15:49:18 2007] [notice] Child 8696: Starting 250 worker
>> threads.
>> [Thu May 03 15:49:18 2007] [warn] FastCGI: server "C:/Program
>> Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe" started
>> (pid 10088)
>> [Thu May 03 15:49:19 2007] [warn] FastCGI: server "C:/Program
>> (pid 9104)
>> [Thu May 03 15:49:20 2007] [warn] FastCGI: server "C:/Program
>> (pid 8828)
>> [Thu May 03 15:49:21 2007] [warn] FastCGI: server "C:/Program
>> (pid 9536)
>> [Thu May 03 15:50:28 2007] [error] [client 127.0.0.1] FastCGI: server
>> "C:/Program
>> stderr: PHP Warning:  fsockopen() [<a
>> href='function.fsockopen'>function.fsockopen</a>]: unable to connect
>> to localhost:8008 (A connection attempt failed because the connected
>> party did not properly respond after a period of time, or established
>> connection failed because connected host has failed to respond.,
>> referer: http://127.0.0.1:8008/mapguide/webstudio/
>> "C:/Program
>> stderr: ) in C:\\Program
>> Files\\MapGuideOpenSource\\WebServerExtensions\\www\\webstudio\\redirect.php
>> on line 87, referer: http://127.0.0.1:8008/mapguide/webstudio/
>> [Thu May 03 15:51:29 2007] [error] [client 127.0.0.1] FastCGI: server
>> "C:/Program
>> "C:/Program
>> "C:/Program
>> stderr: PHP Fatal error:  Maximum execution time of 60 seconds
>> exceeded in C:\\Program
>> Zac Spitzer
>> +61 405 847 168
