[mapguide-users] Help with SID files
George McLean
gmclean at gorge.net
Sat May 5 18:50:58 EDT 2007
Hi Frank,
I am running from the command window as suggested. I created a new map
in Studio with a large coordinate window to be sure I could see the
image but I still can not see it. In the instructions I did not see a
step to add specific files, only to specify the folder containing the
sid files so I that is how I defined the resource.
When I load the web page containing the image layer, I get the following
in the command window. Should I see more, like maybe a sid file loading?
GDAL: Auto Register C:\Program
Files\MapGuideOpenSource\Server\Bin\gdalplugins\gdal_MrSID.dll using
GDALRegister_MrSid.
Thanks again for your help.
George
George McLean wrote:
> Thank you Frank. I will give this a try.
> George
> Frank Warmerdam wrote:
>> On 5/4/07, George McLean <gmclean at gorge.net> wrote:
>>> Hello,
>>> I am having some trouble using Sid files in MGOS 1.1
>>> I have installed the patches from http://home.gdal.org/mapguide
>>> (mg_fdogdal.zip and mg_mrsid_110.zip).
>>> I am building the map using Autodesk Mapguide Studio.
>>> I have the Sid files and associated sdw and aux files in a single
>>> folder
>>> on the machine running mapguide server.
>>> I create a new data connection and choose the OSGeo FDO Provider for
>>> Raster. In the definition form I added the path for the
>>> DefaultRasterFileLocation under connection properties. No username or
>>> password. Under data files I added the Sid file.Test Connection works
>>> and I can save the definition of the feature source.
>>> When I try to create a layer using this data source, I can add the data
>>> source but I can not see the image in the layer preview or when I
>>> add it
>>> to a map used in a web layout. I have tried loading the sdw and aux
>>> file
>>> into the feature resource definition form but I get the same result.
>>> I can see the images using Autocad Map or Arcview. Any suggestions?
>> George,
>> I'd encourage you to run mgserver at the console per the
>> following debug instructions.
>> http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Source_Raster_Provider_with_Studio
>> Hopefully this will at least give a clue if the sid is being opened
>> properly. If so, you should see a message something like
>> GDALOpen(...yourfile...) opened successfully as MrSID.
>> Best regards,
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
