[mapguide-users] Tiled map using GETMAPIMAGE
Andy Morsell
amorsell at spatialgis.com
Thu May 10 12:21:01 EDT 2007
Yes, that is correct. See this RFC for more details on the changes specific
to this issue that will be in 1.2. It will also allow you to specify PNG or
JPG format for the tiles. All of these settings will be global to the site,
however.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, May 10, 2007 4:37 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Tiled map using GETMAPIMAGE
i believe mapguide 1.20 allows configurable tile sizes
z
On 5/10/07, Brendan Cervin <bcervin at gmail.com> wrote:
> Hello velen,
> I stumbled across your mapguide-users enquiry regarding point labeling
> with GETMAPIMAGE. I have made a custom cache for use with my own
> interface, with the exact same problem.
> I wondered if you had a solution to this, or if you live with the
> problem like I do. Here are some thoughts of mine on a solution.
> Use the GETTILEIMAGE command, the drawbacks are, you are limited to
> mapguides positioning, and a hardcoded tile size of 300x300 (which is
> my tile size anyway). This is only available as a PNG as far as I
> know, which I don't like.
> The new 1.2 mapguide is supposed to have several improvements in this
> area, so that could be worth waiting for.
> I have tried playing with base layers to force nice labeling..
> unsuccessfully.
> I have made my image request to GETMAPIMAGE about 2000x2000 pixels to
> limit the occurance of this problem..
> If you have any thoughts on this, please get back to me.
> Cheers, Brendan.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
