[mapguide-users] RE: try to update SDF FeatureSource...my code
don'twork.
Jim O'Leary
joleary.public at gmail.com
Thu May 10 15:06:01 EDT 2007
Hi Jason
My GETRESOURCECONTENT does not look like the one you describe. Here it is:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SHP</Provider>
<Parameter>
<Name>DefaultFileLocation</Name>
<Value>%MG_DATA_FILE_PATH%</Value>
</Parameter>
</FeatureSource>
I have tried adding a <Parameter> tag for ReadOnly and also tried adding a
parameter for <Name>file</Name>. I am able to set the resource, but then
MapGuide cannot find it, or it complains about the readonly in the
connection. I made this package from MGE 1.0.0.17864.
I have the same problem writing to an imported package, so would like to
change the readonly. Any suggestions?
Thanks
JasonBirch wrote:
> Maciek wrote:
> i try update SDF FeatureSource (Roads name of Samples/Sheboygan data
> form MGOS download page) whithout any results
> This may be the same problem that we were having earlier this week.
> When SDF files are initially added to the repository, their ReadOnly
> flag (or something like that) is set to TRUE. This needs to be modified
> using the pages installed on your MapGuide server under
> /mapguide/mapagent/index.html
> First, do a GetResourceContent, specifying
> Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource as your
> ResourceID
> This will give you an XML representation of your data connection's
> definition. View the source of this page, copy it into a text editor
> and modify the following section:
> <Parameter>
> <Name>ReadOnly</Name>
> <Value>TRUE</Value>
> </Parameter>
> replacing TRUE with FALSE.
> Save this file to your local computer.
> Now go back to the mapagent forms, and open the SetResource form. In
> this form, specify your ResourceID
> (Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource) and
> browsing to the location of your saved XML file in the Content section.
> You do not need to fill in the Header area.
> Once this is submitted, you should be able to modify your SDF file.
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/try-to-update-SDF-FeatureSource...my-code-don%27t-work.-tf3333895s16610.html#a10419544
