[mapguide-users] On-the-Fly WebLayout Creation
Jason Birch
Jason.Birch at nanaimo.ca
Fri May 11 11:27:50 EDT 2007
Bob's sessions from last year's AU went into some strategies (both DOM management, and simple string replacement) for managing XML resources.
You can find the relevant session here:
<http://au.autodesk.com/sessions/civilandgeospatial/detail/17111/ <http://au.autodesk.com/sessions/civilandgeospatial/detail/17111/> >
This appears to have been turned into an Autodesk white paper too; Imaginit has it posted (with their branding attached) here:
<http://www.rand.com/imaginit/1/rss/viewitem.asp?feedid=NEWS_ALL&guid=580 <http://www.rand.com/imaginit/1/rss/viewitem.asp?feedid=NEWS_ALL&guid=580> >
But it's not available at <http://www.autodesk.com/learnmapguide <http://www.autodesk.com/learnmapguide> > yet.
Jason
Subject: [mapguide-users] On-the-Fly WebLayout Creation
What would be the best route to take if you wanted to take an XML file (or xml in variable) and create the weblayout on the fly dynamically adding a mapdefinition? I just want to see if there is something easy to follow example wise out there.
