[mapguide-users] OGR Provider cann't load S-57
? at ???? hayashi at trk.apptec.co.jp
Wed May 16 08:17:57 EDT 2007
Hello, List
I'm using MGOS 1.1.0 and AutodeskStudio2007SP1a, getting in trouble in
connecting OGR Provider and S-57(ENC) files to a site.
System Modules and data:
MGOS 1.1.0
FDO 3.2.026
OGRProvider.dll(OGRProvider-3.2.0.win32.zip)
?OGR Provider don't have Version Resource propaty ,Why?
S-57 File:US5TX51M.000(for TEST DATA from Frank's S-57 Page)
S57 Control Options:
OGR_S57_OPTIONS =
RETURN_PRIMITIVES=ON,RETURN_LINKAGES=ON,LNAM_REFS=ON,SPLIT_MULITPOINT=ON,ADD_SOUNDG_DEPTH=ON,PRESERVE_EMPTY_NUMBERS=ON
GDAL_DATA=C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\data
S57_CSV=C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\data
Operation:
1) Run MgServer with the CPL_DEBUG environment variable set to ON.
2) Create data connections for US5TX51M.000(S-57) data.
3) Add new layer and set a s-57 data resource.
----------------debug message--------------------
C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver run
Running the server interactively as an application instead of as a service.
(120|2336) Server starting...
(120|2336) PROJ4 Coordinate System Library
(120|2336) Server started.
destroying connection
Close OGR connection
Attempt OGR connect to C:\demo\S57\ENC_ROOT\US5TX51M.000
ReadOnly 1
OGR: OGROpen(C:\demo\S57\ENC_ROOT\US5TX51M.000/0DBA0048) succeeded as S57.
ReadOnly 1
OGR: OGROpen(C:\demo\S57\ENC_ROOT\US5TX51M.000/0DD51ED0) succeeded as S57.
Feature class name: DSID
Attribute : DSID_EXPP
Attribute : DSID_INTU
Attribute : DSID_DSNM
Attribute : DSID_EDTN
Attribute : DSID_UPDN
Attribute : DSID_UADT
Attribute : DSID_ISDT
Attribute : DSID_STED
Attribute : DSID_PRSP
Attribute : DSID_PSDN
Attribute : DSID_PRED
Attribute : DSID_PROF
Attribute : DSID_AGEN
Attribute : DSID_COMT
Attribute : DSSI_DSTR
Attribute : DSSI_AALL
Attribute : DSSI_NALL
Attribute : DSSI_NOMR
Attribute : DSSI_NOCR
Attribute : DSSI_NOGR
Attribute : DSSI_NOLR
Attribute : DSSI_NOIN
Attribute : DSSI_NOCN
Attribute : DSSI_NOED
Attribute : DSSI_NOFA
Attribute : DSPM_HDAT
Attribute : DSPM_VDAT
Attribute : DSPM_SDAT
Attribute : DSPM_CSCL
Attribute : DSPM_DUNI
Attribute : DSPM_HUNI
Attribute : DSPM_PUNI
Attribute : DSPM_COUN
Attribute : DSPM_COMF
Attribute : DSPM_SOMF
Attribute : DSPM_COMT
Geometry column : GEOMETRY
(3476|3352) An exception occurred in FDO component.
'FdoPtr::operator->': Cannot execute function due to invalid value for the in
put parameter(s) 'p'.
Exception occurred in method MgServerDescribeSchema.ExecuteDescribeSchema at lin
e 187 in file c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src
\services\feature\ServerDescribeSchema.cpp
OGR Provider 3.2.2 and MGOS1.2 beta1 is same.
OGR Provider cann't support S-57(ENC)?
Applied Technology Co.,Ltd.
Hirofumi Hayashi
