[mapguide-users] MySQL connection error - unsupported buffer type?
Andy Morsell
amorsell at spatialgis.com
Tue May 22 11:31:53 EDT 2007
If you install MapGuide Open Source, it includes FDO. You do not need to
worry about downloading, installing or configuring FDO separately. In
MapGuide Studio, just choose the MySQL or ODBC data providers when creating
a feature source and then point that to your MySQL database.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra Kumar
Sent: Tuesday, May 22, 2007 5:09 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MySQL connection error - unsupported buffer
type?
Hi Kevin,
I read your message that you succesfully connect MGOS with MySQL 5.0. I also
want to connect with MySQL but i have not idea where i get FDO 3.2 and how
to install it. In my next project i have to use MySQL as a Database for
runtime layer creation but till now i have not idea. You succesfully connect
with MySQL so, please help me. If you can send any Example or Query feature
then i'll get more help. I am waiting for your replay. Please Help me.
Thankyou in Advance.
Regards,
Dhirendra Kumar
kgrootendorst wrote:
> Hello,
> Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
> I have success with setting up a MySQL connection for an application
> on my local drive.
> Now that I have 'moved' the application to a remote server, I am
> running into a mysql connection error. I can't seem to find anyone
> with a similar problem, nor have I been able to resolve the error with
> any success. Below is a dump from the server log. Does anybody have any
ideas?
> Error: An exception occurred in FDO component.
> RDBMS: Using unsupported buffer type: 0 (parameter: 1)
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\
feature\FeatureServiceHandler.cpp
> - MgOpTestFeatureSourceConnection.Execute line 103 file
feature\OpTestFeatureSourceConnection.cpp
> - MgFdoConnectionManager.Open line 815 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\com
> mon\manager\FdoConnectionManager.cpp
> Thanks in advance.
> Kevin
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/MySQL-connection-error---unsupported-buffer-type--tf36
75443s16610.html#a10736489
