[mapguide-users] Navigation Example .NET
Berdel, Brian
brian.berdel at mcmtrans.com
Wed May 23 11:45:29 EDT 2007
I used 1.2 and it definitely works. I put the server side code in the
gotopoint.aspx on page load then called the refresh after the
ZoomToView.
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Wednesday, May 23, 2007 10:03 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Navigation Example .NET
What version of the MapGuide server did you use?
I cannot get it to update the legend correctly, when the "summary"
parameter is present.
Regards, Kenneth, GEOGRAF A/S
Berdel, Brian wrote:
I take that back...I got it to work.
It was actually much simpler than all of this. And Refresh does in
fact Refresh the legend.
I simply had to call GetMapFrame().Refresh();
Before calling ZoomToView
All is well and it works great.
Thanks again for all of your help.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Tuesday, May 22, 2007 9:50 AM
Subject: RE: [mapguide-users] Navigation Example .NET
I cannot get it to work with your workaround. (or with any I have tried
I took out the summary parameter and made the change to
ajaxmappane.templ
And the map will not display at all. This seems like a pretty basic
piece of functionality that has gone without working for a long time. I
found e-mails on this dated back to October.
Thanks,
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
Sent: Monday, May 21, 2007 2:33 PM
I can't find it either :D...
Here is the text of my post:
<snip>
When using the server API for altering layer visibility, a call to the
GetMapFrame().Refresh() is not sufficient to refresh the legend.
Pseudocode:
$map.Open(...);
$map.Layers('layername').setVisibility(true);
$map.Save();
Calling the GetMapFrame().Refresh() after this, will update the map to
display the new layer.
However the Legend does not reflect this change.
The problem can be solved with two changes:
1. In ajaxmappane.templ, the Refresh() function should also call
ResetVisLayers()
2. In legendctrl.templ, the Refresh call should be changed, so it does
not call with the summary parameter
The problem only occurs in the AJAX viewer.
When retrieving the legend script, using the summary parameter, the
visibility does not change.
Removing the summary parameter is a bad fix, as it also disables the
optimizations that the summary parameter gives.
If the above mentioned fix 1, is not implemented, a lot of features will
fail after modifying the map.
For instance tooltips for the layers will not work.
I think this is a problem with a design flaw in the way the viewer is
implemented.
Keeping state data solely on the client is a very bad idea.
This happens with layerstates and current zoom in the AJAX viewer, and
the Selection in the DWF viewer.
To allow modifications to the map from the server API, all data should
be written to the server.
To provide caching the client should fetch a change list, rather than
sporadically caching data.
Using a sequence number, the client can skip multiple update cycles, and
still be synced correctly.
Using a generic format would allow the DWF and ajax viewer to work on
exactly the same data, thus reducing duplicate code.
</snip>
Looks like you are right...Thanks. I cannot seem to find your
workaround, can you send me a link or something?
Thanks,
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
Sent: Monday, May 21, 2007 9:58 AM
The zoom will invalidate the map, and is the same as a refresh.
I haven't tested it, but I don't think a scale change (eg. zoom) will
refresh the visible layer cache, but it might.
Andy Morsell wrote:
But in the example below, where the layer is being set to visible right
before a zoom, the zoom should take care of the map refresh and the
layer should appear on the subsequent map. Or, is this not the case?
Andy
Sent: Sunday, May 20, 2007 11:18 AM
If you modify the layer visibility, using serverside code, it will not
work correctly with the AJAX viewer.
The problem is that the AJAX client has a small cache of visible layers,
and calling map.refresh() on the client does not invalidate this cache.
The symptoms will be that no tooltip is displayed for the layer, and the
layer never shows up in the legend.
I've posted this bug on the mapguide-internals list, and a workaround.
Regards. Kenneth, GEOGRAF A/S
Cool, thanks! I'll give it a try.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
size=2 width="100%" align=center tabindex=-1>
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Friday, May 18, 2007 12:39 PM
To: 'MapGuide Users Mail List'
The execution of the API functions must happen server side in this
instance. But, it looks like you could put your .NET conditional code
in the gotopoint.aspx page and it would work. The OnPageLoad()
javascript function would fire afterwards so all should behave smoothly.
And, you would not have to programmatically refresh the map since that
will happen with the ZoomToView anyway.
Andy
Brian
Sent: Friday, May 18, 2007 9:28 AM
Thanks for the response. I am looking for a way to achieve this on the
client side. I do not want to check until after the user has clicked on
link. (such as putting it in the gotopoint.aspx page). Will this work
here?
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
Morsell
Sent: Friday, May 18, 2007 11:40 AM
You should be able to use the MgLayer::IsVisible function to check the
visibility and then SetVisible to turn it on. You will then have to
refresh the map to reflect the change.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Brian
Sent: Friday, May 18, 2007 8:00 AM
Subject: [mapguide-users] Navigation Example .NET
Anyone know how I would go about checking to see if a layer was on in
the navigation example and if it is not turn it when clicking a link.
Thanks!
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070523/0e80f544/attachment.html
