[mapguide-users] Bug in Selection polygon from PostGiS
(PostgreSql)
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri May 25 07:05:33 EDT 2007
I've had a similiar problem with an older version of the OGR provider.
What happens when you deselect the polygon?
Can you try with MG 1.2.0 Beta 2, and Traian's OGR for FDO 3.2.2 ?
If it works, I'll see if I can compile Postgres support into OGR for FDO
3.2.
I don't think you can use my version of the OGR, as there were no
Postgres support in that one.
Regards, Kenneth, GEOGRAF A/S
Maciej Skorczewski wrote:
> Hi!
> Use MG 1.1.0, XP,PHP
> I my aplication i store all layer in PostGis database (PostgreSql
> database).
> I see all layers correct but have problem whit correct selection of
> it. This are plans of rooms in building.
> I use Base Layers (Ajax Tile base) problem looks like this (look in
> print screen).
> http://img340.imageshack.us/img340/4928/bugpostgisey2.jpg
> when i try this same whit shp files all works ok (i can select this
> smaller polygon) ...so i thing that problem is whit Ogr provider, or
> maybe it is BUG in MapGuide.
> Can anybody tell me what can i do whit this problem.? Did you have
> this same problem?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
