[mapguide-users] Can't insert feature into certain SDFs
Takashige Nakagawa
ta-nakagawa at apptec.co.jp
Fri May 25 07:37:24 EDT 2007
Hi, all.
Since I posted the last mail, I've tried a lot.
But I still can't insert features into some SDFs (And I can do it into
others).
I can delete and update features of them.Only the insertion wouldn't work.
I don' know what's wrong.
The schema is like below. Any ideas?
Thanks.
Takashige Nakagawa
<?xml version="1.0" encoding="UTF-8" ?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://fdo.osgeo.org/schemas/feature/SHP_Schema"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:gml="http://www.opengis.net/gml"
xmlns:SHP_Schema="http://fdo.osgeo.org/schemas/feature/SHP_Schema"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
<xs:documentation />
</xs:annotation>
<xs:element name="Test" type="SHP_Schema:TestType" abstract="false"
substitutionGroup="gml:_Feature">
<xs:key name="TestKey">
<xs:selector xpath=".//Test" />
<xs:field xpath="Autogenerated_SDF_ID" />
</xs:key>
</xs:element>
<xs:complexType name="TestType" abstract="false" fdo:geometryName="SHPGEOM">
<xs:annotation>
<xs:appinfo source="http://fdo.osgeo.org/schemas" />
</xs:annotation>
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="Autogenerated_SDF_ID" fdo:readOnly="true" minOccurs="0"
fdo:autogenerated="true">
<xs:simpleType>
<xs:restriction base="fdo:int32" />
</xs:simpleType>
<xs:annotation>
<xs:documentation>Autogenerated identity property</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="SHPGEOM" type="gml:AbstractGeometryType"
fdo:hasMeasure="false" fdo:hasElevation="false" fdo:geometricTypes="surface"
fdo:geometryTypes="polygon multipolygon curvepolygon multicurvepolygon">
<xs:annotation>
<xs:documentation>The geometry of the object</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="Name" minOccurs="0">
<xs:annotation>
</xs:annotation>
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="" />
</xs:restriction>
</xs:simpleType>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
>I could be wrong, but I believe there were/are some restrictions around
>altering the schema of existing SDF files.
> You might have to extract your existing SDF schema to XML, alter it,
> create a new SDF, apply the altered schema, and transfer the data.
> Jason
> ________________________________
> From: Takashige Nakagawa
> Subject: [mapguide-users] Can't insert feature into certain SDFs
> Hi all.
> I've been testing my code which insert features into SDFs and it worked
> well
> so far.
> When it comes to certain SDFs, however, it wouldn't work.
> I can delete and update features of these SDFs, so "Read Only" issue seems
> not to have anything with this problem.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
