[mapguide-users] MapGuide 1.2 Beta2, Login Error
Brad Nesom kidsmake6 at msn.com
Fri May 25 11:04:32 EDT 2007
So on my mapguide virtual dir I should change from 2.0 back to 1.1 in all
cases? Or just in the case that I have an application built on 1.1? It
sounded as though this would fix my webstudio login problem.
BTW I am just watching now because I don't have a productions mgos, I don't
have any trial left on studio and my webstudio won't allow login (plus I'm
not sure I could do much more than manage what I have already set up with
webstudio anyway), And I am not a programmer (just looking for cots
solutions (commercial off the shelf solutions). Maybe by watching some of
all you programmers will rub off on me.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Friday, May 25, 2007 1:50 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide 1.2 Beta2, Login Error
The right version for MapGuide is 2.0.50727 aka 2.0.
And Andy is right, they co-exist, which can be rather confusing and has
some drawbacks.
I have never thought of the idea, that the default .Net version is the
one selected for the root folder of IIS, but it make  very good sense.
I have created a ticket for the problem, I don't know if it is actually
possible to change the default .Net version, as even the Visual Studio
2005 Installer for web applications has the same bug.
Mvh. Kenneth, GEOGRAF A/S
tlf.: +45 48 16 67 14
ks at geograf.dk
Andy Morsell wrote:
> Brad,
> If a server has ASP.NET 1.1.4322 installed and then you install .NET 2.0,
> the two co-exist rather than the new overwriting the old.  This is good
> since some applications written for 1.1 are not compatible with 2.0 so you
> can choose which version to use on an application by application basis.
> This same thing has happened to me several times on different servers and
is
> the first thing I check on the mapguide virtual directory in IIS.  I
believe
> it occurs if you have the root default web site properties set to use 1.1
so
> the MapGuide installer assumes that is the version to use when the
mapguide
> virtual directory is created.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Thursday, May 24, 2007 1:59 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] MapGuide 1.2 Beta2, Login Error
> How did you know what the right version was? What was it?
> I have 2.0.50727
> GEOGRAF A/S
> Sent: Thursday, May 24, 2007 4:42 AM
> Subject: [mapguide-users] MapGuide 1.2 Beta2, Login Error
> After installing the MapGuide 1.2 Beta 2, I could not login to the
MapGuide
> Site Admin. Tried restarting the server, but no change.
> Finally, I found out that the Installer had selected the wrong version of
> the .Net framework in IIS. Selecting the correct version on the top
> "mapguide" folder, fixed the login problem. Not sure why, since the site
> admin is running with php.
> Is it a know defect that the wrong version is selected?
> Regards, Kenneth, GEOGRAF A/S
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
