[mapguide-users] Converting from Enterprise to Open Source (proj4
convert)
Chris Gountanis
cgountanis at mpower-tech.com
Fri May 25 14:51:37 EDT 2007
What is the easiest way to take you SHP file PRJ files which where used in
Enterprise and convert them to the PROJ4 format so MGOS can work its magic?
It's easy to go the other way around just not familiar with PROJ4. Seems
Studio Enterprise uses the commercial version as well. Since MapGuide still
has that bug when you specify a Cord System in Load Procedure it does not
copy over. This seems to easy but for some reason I can't remember how to do
this. Any ideas?
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070525/4983d286/attachment.html
