[mapguide-users] Pulling USERNAME from MapGuide
Hidekazu Shimaji hshimaji at ybb.ne.jp
Fri May 25 23:58:25 EDT 2007
Hello,
I don't think it is possible to get a username which is logging in.
Why don't you keep the username in a web session at the log on page?
I mean that you should post back first, then redirect to the web layout.
Regards,
Hidekazu
--- Rich Bauer <rdbauer at gmail.com> wrote:
> Hi all,
> I am new to this mailing list, so I don't know if this question has been
> asked before (I also tried to find it in the archive with no success).
> The question is I am trying to let the "user" access the data intended
> for them.
> Example:  User "Bill" logs on using a log on page and is taken to the
> weblayout and everything just fine.  Then when "Bill" tries to access a
> command that creates a "Markup" using sample code I found on the
> internet, I want "Bill" to be able to access his markup and not
> everyones.  In other words, I would like to change the path from:
> Library://Markup/     to     Library://Bill/Markup/
> The only problem I am having is getting the username, "Bill", into the
> string that is sent by the code.
> My thought was using the $_REQUEST['USERNAME'] or something, but can't
> get it working.  By the way, the user "Bill" is the user under the
> MapAdmin panel and that.  Any help would be nice.  Thanks.
> Rich
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
