[mapguide-users] Localizing menus and toolbar
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sat May 26 09:12:33 EDT 2007
Ok.
I guess it would be simple to write a small app that loads the weblayot
xml, translates the fields, and writes it into the session repository.
Thanks for you reply.
Regards, Kenneth, GEOGRAF A/S
Chris Claydon wrote:
> Unfortunately there's no way to do this yet. You'll need to create a
> copy of your weblayout, and localize the strings it contains.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: May 25, 2007 5:53 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Localizing menus and toolbar
> Is there a way to localize the toolbar and menu's?
> The current localizations work fine (except for the API default locale
> problem), but only allows localization of "MapGuide" items, and not the
> userdefined items. I would like to use a similar approach for having
> multiple languages for the same WebLayout.
