[mapguide-users] MySQL Database Feature Source Cordiante System
Dave Wilson dave.wilson at autodesk.com
Mon May 28 13:27:08 EDT 2007
As per my previous email unless you have the new MGOS beta there is no
field to specify a coordinate system override since currently MySQL
doesn't support coordinate systems in the native schema. You can specify
the correct coordinate system in your map but you will have to zoom and
find the data to set the extent yourself.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
Kumar
Sent: Monday, May 28, 2007 5:07 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MySQL Database Feature Source Cordiante System
Hi All,
I have successfully established connection of MySQL 5.0 Database and
mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but when
creating Layer using this data source then layer is not showing in
autodesk
Layer Preview window, I think this is happning due to cordinate system,
If i
am right then where is option of providing cordinate system of MySQL
data
source ? If i am wrong then please give me idea, How to solve this
problem ?
Regards,
Dhirendra Kumar
View this message in context:
http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
827380s16610.html#a10834515
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
