[mapguide-users] MapGuide Automated Tiling Engine
MaciekS msiedlaczek at techmex.com.pl
Mon May 28 19:00:45 EDT 2007
Hi everyone!
I tried to use tiling engine - fmtilingengine
Unfortunatelly with no results. May you help me, what did I wrong?
I called program: fmtilingengine -u Administrator -p *** -m 1014Tile
My Error log:
Title: Error
Message: Failed to retrieve message for "MgFileNotFoundException".
StackTrace: Failed to retrieve message for "MgFileNotFoundException".
Exception occured in method ByteSourceFileImpl.LoadFile at line 126 in file
.\System\ByteSourceFileImpl.cpp
Date/Time: 2007-05-29 00:33:05
Title: Error
Date/Time: 2007-05-29 00:33:08
Title: Error
Date/Time: 2007-05-29 00:33:09
Regards, Maciek
_____________________________
Hi everyone,
Websoft Developers is pleased to announce the availability of our free
MapGuide tiling utility.
You may download the installation file from the following link:
Http://www.websoftdev.com/download.cfm
This is a command line utility that can be accessed via a windows console
window or executed via a batch file.
For those familiar with SDF Loader for MapGuide 6.5, this will be familiar
territory.
Note:
1) The application has been tested with .NET MapGuide extensions only.
2) The application works on the Windows platform only, with apologies to all
the Linux users.
2) Replace MapGuide Open DLLs/webconfig.ini with MapGuide Enterprise
DLLs/webconfig.ini for use with Enterprise.
Please provide feedback for any bugs and application hangs, etc.
If you have any difficulties downloading, wait till the end of Monday and
try again.
More details follow below.
Enjoy!
  _____
 <http://www.websoftdev.com/>
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
 <mailto:kori.maleski at websoftdev.com> kori.maleski at websoftdev.com
  _____
FacilitiesMap Tiling Engine for MapGuide Open Source/Enterprise
The Tiling Engine is a batch utility to be used with MapGuide tiled maps.
Aim is to create a utility that will handle the pre-generation of tiled maps
that utilize Base Layers.
This utility is being made available for use to the MapGuide community.
You are free to use it.
Main features:
*	Support for MapGuide Open/Enterprise
*	Use of Command line parameters
*	Configurable in a batch script for automated tiling
*	Tile a specific map
*	Tile a specific Base Layer Group
*	Tile a specific Zoom Threshold
*	Tile a specific Tile index by minimum/maximum
*	Restrict Tiling by Authentication to a specific Map or resource
 Version 0.1.0 :
*	Support for MapGuide 1.1.0 , MapGuide Enterprise SP1
*	.NET Only
Testing Platform and versions:
*	MapGuide Open 1.1.0, MapGuide Enterprise SP1
*	Laptop: Windows XP SP2 P4 Duo Core 2GHz with 2G RAM
*	Tested with .NET MapGuide Components Only.
This is a work in progress; please direct any comments or concerns here:
info at websoftdev.com
FacilitiesMap Tiling Engine Instructions:
            Accessing Help & Instructions
               -h or -help                  Help Menu
             Required Parameters:
               -u or -user                  MapGuide UserName
               -p or -password          MapGuide Password
Optional Parameters:
               -m or -map                 Specify a specific map by name
               -g or -group                Specify a specific base layer
group by name
               -s or -scale                 Specify a specific finite scale
               -sx                             Specify a starting tile
column (x)
               -sy                             Specify a starting tile row
(y)
               -ex                            Specify an end tile row (x)
               -ey                            Specify an end tile row (y)
Enable Log File:
               -l or -log                     Verbose ouput to a log file
Usage:
               FmTilingEngine -u myUseName -p myPassword
*          This will tile ALL maps accessible to this user
*          This will tile ALL base layer groups accessible to this user
               FmTilingEngine -u myUseName -p myPassword -m SheboyganTiled
*          This will tile ONLY the map specified and accessible to this user
The g, s, sx, sy, ex, ey parameters are available only when the m parameter
- map name -
is  specified.
-g 'Base Layer Group'
*          This will tile ONLY the base layer groups accessible to this user
                    -g 'Base Layer Group' -s 7196 -sx 2 -sy 2 -ex 15 -ey 20
user.
*          This will tile ONLY the specified Scale
*          This will tile ONLY the specified tile rows and columns
*          Any combination of the sx, sy, ex, ey parameters may be
specified.
*          Defaulted to the starting and ending column/rows if left
unspecified.
Specifying Starting/Ending Row/Columns is specifically meant for generating
tiles for an area
subset in the case of a map finite scale requiring a significant amount of
tiles.
In general, the -m map, -g group will be the main options utilized.
Be warned - tiling can be computationally intensive.  It is recommended that
in the process be
run on a development or staging machine, and the tile cache be copied to the
production server
 upon completion.  This will depend on your map extents and tile
requirements.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MapGuide-Automated-Tiling-Engine-tf3660489s16610.html#a10845534
