[mapguide-users] RE: MapGuide Automated Tiling Engine
MaciekS msiedlaczek at techmex.com.pl
Tue May 29 18:14:21 EDT 2007
Hi Kori,
you were right. I copied dll files from bin folder and webconfig.ini to the
Tiling Engine folder and run it.
Now i'm happy - files are being generating.
If i'm not wrong, files provided with instalator of  the Tiling Engine are
dedicated for MG Open Source - my solution runs on MG Enterprise - so when I
replaced them by MGE DLLs all is OK.
I'd like to thanku you for creating this powerfull tool. Now life is easier!
Regards, Maciek :)
Kori Maleski-3 wrote:
> Hi Maciek,
> This looks like an issue with the DLLs.
> Can you please detail where your installation of MapGuide is ( C, D or
> other
> drive), and if you are running the TilingEngine from its default
> installation folder?
> Please try the following:
> Backup the Tiling Engine folder.
> Copy the contents of your C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin folder
> to
> Copy the file C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\
> webconfig.ini to the folder.
> Then try running the exe from the command line again.
> Let me know whether the issue persists.
> Cheers,
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MaciekS
> Sent: Monday, May 28, 2007 4:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MapGuide Automated Tiling Engine
> Hi everyone!
> I tried to use tiling engine - fmtilingengine
> Unfortunatelly with no results. May you help me, what did I wrong?
> I called program: fmtilingengine -u Administrator -p *** -m 1014Tile
> My Error log:
> Title: Error
> Message: Failed to retrieve message for "MgFileNotFoundException".
> StackTrace: Failed to retrieve message for "MgFileNotFoundException".
> Exception occured in method ByteSourceFileImpl.LoadFile at line 126 in
> file
> .\System\ByteSourceFileImpl.cpp
View this message in context: http://www.nabble.com/MapGuide-Automated-Tiling-Engine-tf3660489s16610.html#a10863819
