[mapguide-users] [Mapguide studio]?
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed May 30 07:00:32 EDT 2007
Yes, that is possible.
You should read the the developers manual, it has all the required steps
described.
You can also look at WebStudio to see a live working sample.
Regards, Kenneth, GEOGRAF A/S
Mansoureh Sadrykia wrote:
> Thanks for your help Kenneth, GEORGE A/S
> I actually would like to see if I can make a weblayout from shape
> files and display it in http://localhost:8008/mapguide/... by writing
> PHP code and without using mapguide studio.
> Is that  possible?
> Thanks in advance,
> */"Kenneth, GEOGRAF A/S" <ks at geograf.dk>/* wrote:
>     I'm not sure what you want to do. There is no studio involved in
>     displaying a map.
>     You can just browse to a layout (mine is called Layout1, and is in
>     the root folder in studio):
>     http://localhost:8008/mapguide/mapviewerajax/?WEBLAYOUT=Library://Layout1.WebLayout
>     If you want to remove the Login box, you have to copy paste some
>     code from one of the Viewer Samples (.Net, PHP or Java).
>     If you want to design another map without studio, I would advise
>     you to try out WebStudio. If you feel *really* adventurous, you
>     can try the http interface, but you will have to be a programmer
>     or similiar to go that way.
>>     Hi Everybody!
>>     I'm new in mapguide and have a question; I've used mapguide
>>     studio to generate a weblayout from shape files and could display
>>     it in the browser in mapguide open source using AJAX Viewer
>>     (http://localhost:8008/mapguide). Now I would like to know if I
>>     can do the same (display the map of shp filesin internet
>>     explorer) _*WITHOUT*_ using mapguide studio ?
>>     I'd be thankful if anybody introduce me some example or document
>>     for this.
>>     Thanks alot in advance,
>>     Don't get soaked. Take a quick peak at the forecast
>>     <http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news>
>>     with theYahoo! Search weather shortcut.
>>       _______________________________________________  mapguide-users mailing list  mapguide-users at lists.osgeo.org  http://lists.osgeo.org/mailman/listinfo/mapguide-users
> TV dinner still cooling?
> Check out "Tonight's Picks"
> <http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/> on Yahoo! TV.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070530/42c10a0a/attachment.html
