[mapguide-users] Unmanaged SHP File Locations
Traian Stanev
traian.stanev at autodesk.com
Wed May 30 11:41:31 EDT 2007
SDF has no configuration files. Also, with SDF you never connect to a
whole directory, you always connect to a single file.
So in short, they are not affected.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, May 30, 2007 11:16 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Unmanaged SHP File Locations
I'd be interested in knowing whether turning on connection pooling makes
a difference.
If it does, having a single slow request every 10 minutes might not be
such a bitter pill, at least until it's fixed properly.
Does this affect SDF files as well? I'd imagine that they're different,
but I'm not sure how MapGuide handles multiple SDF files in a single
directory... There's an additional level of complexity there; multiple
classes per schema.
Jason
I am also available to test if needed.
By turning on connection pooling for the SHP provider, the server will
cache the connection so the next time it is accessed, things should be
quick. However, the cached connection gets purged every 10 minutes
(default) or so, so if the connection has been removed from the cache,
the next person to access the resource will still have to wait... hmmm,
sounds like we should still investigate the root problem of the
slowness.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
