[mapguide-users] RE: scale bar always says Meters
Jon Rizzo jrizzo at Langan.com
Wed May 30 16:42:36 EDT 2007
That did the trick.  Thank you for such a quick response!
Jon
Chris Gountanis wrote:
> In the code that creates the plot you need to change something. US-English
> means Feet. For some reason the constants don't work anymore.
> layout =  new MgLayout(layoutRes, "Title Goes Here", "US-English");
> Chris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jon Rizzo
> Sent: Wednesday, May 30, 2007 3:29 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] scale bar always says Meters
> Hello,
> I have created a page that generates a DWF file of the current map.  The
> map's units are *XY-IN* (Arbitrary X-Y Coordinates (U.S. Survey Inches)).
> In the routine that generates the plot, I am creating an
> MgPlotSpecification
> with the units MgPageUnitsType.Inches which I pass in the call to
> GeneratePlot.  I specified a scale of 120, so the resulting plot should be
> shown as 1" = 10' or 1" = 120".  However, when the plot is generated, the
> scale bar always shows up in Meters.  Is there any way to fix the scale
> bar
> to show values that make sense for a non-metric map?
> Jon
> http://www.nabble.com/scale-bar-always-says-Meters-tf3842795s16610.html#a108
> 81997
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/scale-bar-always-says-Meters-tf3842795s16610.html#a10882201
