[mapguide-users] Can't insert feature into certain SDFs
Takashige Nakagawa
ta-nakagawa at apptec.co.jp
Thu May 31 02:09:44 EDT 2007
It's SDF3.
I created 2 versions of Test2.sdf.
version 1
This is created by FDO2FDO, copying the schema of Test.sdf.
version 2
First, I created empty SHP (Test2_org.shp) by ArcCatalog.
Next, I loaded it via Mapguide Studio into a feature source from which I
downloaded Test2_org.sdf.
Then I edited the properties ( setting autogenerated, nullable and read -
only attributes) of the Test2_org.sdf and exported it as Test2.sdf.
Regards.
Takashige Nakagawa
----- Original Message -----
> Is test2.sdf an SDF3 file or an older sdf2 file that you're converting?
> How did you create it?
> Jason
