[mapguide-users] About Redling
Rich Bauer rdbauer at gmail.com
Thu May 31 14:18:33 EDT 2007
I sounds like what you want is the "Markup" feature in the following
white paper.
http://images.autodesk.com/adsk/files/working_with_resources_mapguide_enterprise_white_paper.pdf
At the bottom in resources,
http://data.mapguide.com/mapguide/gt/index.php, will take you the the
sample as well as provide for you downloading the sample code on the
right hand side.
Once you have that, see my post
http://www.nabble.com/Pulling-USERNAME-from-MapGuide-tf3810822s16610.html
for the ability to add the login username as the folder to pull the
layers from for the map.
Hope this helps.
Rich
Anil Jose wrote:
> Please anybody send me the complete code for drawing a point and
> polygon on the map. My requirement is not just showing the poins or
> polygon on map. It should permenantly saved. After a user sign out and
> try login again he can see what he has drawn. Please help me..
> Thanks..
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
