[mapguide-users] security exception webconfig.ini
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Nov 1 09:54:17 EDT 2007
Odd, the only thing I can think of is that you are using another App
Pool in IIS.
Have you tried calling any other methods, in order to determine if the
problem is related to InitializeWebTier, or the load/use of the MapGuide
package?
The .Net dll calls a bunch of native Dll's (all those found in the "Bin"
folder),
the problem may be related to loading one of those, rather than a
problem with the WebConfig.ini.
You can try System.IO.File.Open(Server.MapPath("webConfig.ini")) to
determine if you have the correct permissions.
If you can open the file, the problem is related to the native calls,
and that can be a bit harder to debug.
You should copy the files into you own folder, and not reference the
existing path (due to IIS security restrictions).
Regards, Kenneth, GEOGRAF A/S
william MGOS skrev:
> Hi , the user identity in IIS under directory sercurity is IUSR_.
> the ex.message is: System.Security.Permissions.SecurityPermission
> that's really all I have at this point.
> The sample application from OSGEO is working, the only difference is
> that I have put my app in visual studio, cause I'm trying to setup a
> clean development environment...
> On Nov 1, 2007 12:38 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
>> What is the exception message?
>> Perhaps the application is not trusted?
>> Did you modify the user that the application runs under? (in IIS).
>> william MGOS skrev:
>> hi,
>> I have already tried that, all those users have full persmissions
>> on
>> the folder / files.
>> what else could be wronh?
>> On Nov 1, 2007 12:19 PM,
>> That looks like the caller (IUSR or NETWORK SERVICE) is not allowed to
>> open
>> the file.
>> Try right clicking the file and adjust permissions for the
>> "Everyone"
>> user, start with "Full control".
>> If it works, remove it again and
>> ajust permissions for either
>> IUSR_<machinename> or
>> NETWORK_SERVICE.
>> william MGOS skrev:
>> Hi,
>> i created an IIS webapplication and created a page. In the load
>> event
>> of the page I put this. The file exists, so mgInitializeWebTier
>> is
>> called. Now it throws an exception. What could this
>> be?
>> System.Security.SecurityException:
>> at MapGuideApi.MgInitializeWebTier(String configFile)
>> string filename;
>> filename = Server.MapPath("webconfig.ini");
>> try{
>> if
>> (File.Exists(filename))
>> MapGuideApi.MgInitializeWebTier(filename);
>> }catch(Exception
>> ex)
>> mapguide-users
>> mailing
>> list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> mapguide-users mailing
>> list
>> list
>> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071101/b1a6bcae/attachment.html
