[mapguide-users] EXTERNAL_API not documented in doxygen
Bruce Dechant
bruce.dechant at autodesk.com
Thu Nov 1 15:50:42 EDT 2007
There are 3 defines that control what ends up in the API and what is documented.
1) PUBLISHED_API
- These APIs are documented and officially supported.
2) EXTERNAL_API
- These APIs are NOT documented because they are NOT officially supported and may be removed in a future release without warning.
- Some of these APIs may end up as "PUBLISHED_API" and officially supported in a future release.
3) INTERNAL_API
- These APIs are not exposed in the web tier.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: October 27, 2007 3:10 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] EXTERNAL_API not documented in doxygen
Is there a good reason why some public methods are not documented in the
doxygen output for MGOS? For example, in a typical code sample I see:
$site = new MgSite();
$site->Open($userInfo);
These methods are not documented in the doxygen output, which could be
confusing if you are trying to understand the code. However, in the source
code at:
Common\MapGuideCommon\Services.Site.h
I see:
EXTERNAL_API:
/// \brief
/// Construct an MgSite object and open a connection to the Site Server.
/// \return
/// Nothing
MgSite();
/// \brief
/// Opens a connection to the Site Server.
/// \param userInformation
/// User information to authenticate against
/// \return
/// Nothing
/// \exception MgNullArgumentException
/// \exception MgAuthenticationFailedException
/// \exception MgConnectionFailedException
void Open(MgUserInformation* userInformation);
...and other methods. So it appears that code that is under EXTERNAL_API
does not make it into doxygen.
Thanks.
View this message in context: http://www.nabble.com/EXTERNAL_API-not-documented-in-doxygen-tf4704536s16610.html#a13447448
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
