[mapguide-users] Error.log of MapGuide Enterprise
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Nov 3 13:15:01 EDT 2007
It should be located in server/bin/fdo, along with at least
SDFProvider.o and SHPProvider.o.
I'm unfamilliar with the Linux install package, but you need the FDO
Providers, if they are not included in the package.
Regards, Kenneth, GEOGRAF A/S
Eric123 skrev:
> Thanks Jack.
> I try to locate "providers.xml". Nothing can find. What is the exact
> directory for the file?
> Eric
> Jack Lee-3 wrote:
>> Hi,
>> Does the file providers.xml exist?
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric123
>> Sent: Saturday, November 03, 2007 7:45 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Error.log of MapGuide Enterprise
>> Hi All.
>> I just installed the MGE2008 to Fedora Core 4. Actually I try to use
>> MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
>> generated. OK I check with the error.log. I got the following warning.
>> Anyone know how to fix? Do I need to re-install/compile FDO?
>> Thanks in advance.
>> Eric>-(
>> <2007-11-01T16:49:15>                   Administrator
>>  Error: An exception occurred in FDO component.
>>         CLNT_12_FILE_NOT_EXISTS
>>  StackTrace:
>>   - MgFeatureServiceHandler.ProcessOperation line 83 file
>> FeatureServiceHandler.cpp
>>   - MgOpGetIdentityProperties.Execute line 116 file
>> OpGetIdentityProperties.cpp
>>   - MgServerDescribeSchema.GetIdentityProperties line 1581 file
>> ServerDescribeSchema.cpp
>>   - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
>>   - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp  An
>> <2007-11-01T16:49:16>                   Administrator
>>  Error: Failed to stylize layer: CityLimits
>>  StackTrace:
>>   - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
>> View this message in context:
>> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071103/d2be3661/attachment.html
