[mapguide-users] Error: Failed to stylize layer (WMS Connection over https)
Eric123 erictsn at cadbeyond.com
Sat Nov 3 21:43:47 EDT 2007
I using MapGuide Enterprise 2008 in Linux version. The FDO is 3.2.2. I have
captured a bit of error msg as below:
<2007-10-31T18:43:36>                   Administrator
 Error: An exception occurred in FDO component.
        CLNT_12_FILE_NOT_EXISTS
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute line 116 file
OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties line 1581 file
ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
  - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp  An
<2007-10-31T18:43:38>                   Administrator
 Error: Failed to stylize layer: Islands
 StackTrace:
  - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
What is the warning message? Is it permission problem? I was used Root
account for installing everything.
Regards,
Eric
zspitzer wrote:
> which release are u running? if it's still happening with 1.20 file a
> bug in trac
> http://trac.osgeo.org/mapguide/
> z
> On 11/3/07, Eric123 <erictsn at cadbeyond.com> wrote:
>>  I have same question too. Anyone know?
>> Jose Manuel C G wrote:
>> > I have the same problem. Have you fix it?
>> View this message in context:
>> http://www.nabble.com/Error%3A-Failed-to-stylize-layer-%28WMS-Connection-over-https%29-tf3108961s16610.html#a13562200
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> http://zacster.blogspot.com/
> +61 405 847 168 (aussie moible)
View this message in context: http://www.nabble.com/Error%3A-Failed-to-stylize-layer-%28WMS-Connection-over-https%29-tf3108961s16610.html#a13569201
